JGR
Gabe
For SR5 owners, when replacing the lower grill — is that portion a camera hole a sensor or simply a cover cap?
Interested in doing this with the lightbar.
AKruzer
Cleveland, OH
2025 4Runner SR5 4x4
Did you ever get an answer on this? I’m curious as well
JGR
Gabe
It’s a blank cover, no camera down there. The vision system comes from the mirror area on windshield.
LIVELY
Anaheim, CA
2025 4Runner Off Road Premium
Gonna do the Grille Swap here in the next few weeks. I have the camera though, other than relocating it and splitting the harness so it reaches, do i have to replace the bracket or is it just an easy swap? Does it need recalibrated?
Maximus4R
Adam
Nashville
You’ll need a bracket. I used the Rave one and it works perfectly. Came with a tiny torx driver to remove the current screws and remount. I think there are some cheaper ones out there, I just only have personal experience with this one.
https://raveoffroad.com/products/ca...lltF8-uy8vjc1O-mH7WEaKsqGcdSeMhsPE6-V6gqQyc9L
There’s a process to do small calibration changes (or you can pay the dealer to do a full update) but on my current one I haven’t messed with it and it’s not terribly noticeable honestly.
https://www.tacoma4g.com/forum/attachments/camera-calibration-pdf.31175/
Dead Horse
Oklahoma
Curious if anybody has been able to get the connector/wiring for the factory light bar.
I just bought a factory light bar, and have all the rest of the parts to make the switch. I just have to figure out how to wire it to one of my factory aux switches. Having the OEM connector for the back of the light would be optimal, I think. But I can't find the ding dang dong part number or connector code/thing to look it up.
Maximus4R
Adam
Nashville
Was really wanting this too so following along. Thinking about doing the same and really want the oem plug for the light bar.
Maximus4R
Adam
Nashville
Also, what the heck could all these pins even for!?
2025 2026 4runner 6th gen TRD Pro/Trailhunter Heritage Grille Swap (Upper & Lower Grill) on SR5, with part numbers IMG_1505
Dead Horse
Oklahoma
I bought the factory light bar, should be here next week (weather is gonna hose up delivery times I'm sure). If I have to sit at a dealership parts guy for 30 minutes to find the connector, I will.
I'm assuming that the extra connections are for control via high beams and a couple of other parameters, unlike aftermarket bars. I just need the hot and ground LOL
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
Maximus4R
Adam
Nashville
This connector is similar. But would be a $96.30 mistake if incorrect.
https://connectorexperts.com/i-24488621-cet1013.html
These guys also take requests to help identify a connector when you send pics.
https://connectorexperts.com/if-5848-connector-quote.html
Whoa. That looks crazy close. I image searched and found one on Ali express for around $15. I don’t have the light bar yet though, sort of dependent on us figuring out how to power it.
https://www.aliexpress.us/item/3256804286650533.html?gatewayAdapt=glo2usa4itemAdapt
Maximus4R
Adam
Nashville
My light bar decision hinges on your success or failure. No pressure
Dead Horse
Oklahoma
I don't actually care about having a light bar, I just like the look of the grills. So I'm not spending $500 on a Heretic or something equally cool. Factory bar is fine. And eBay has them for $200+.
I'll make this shit work :D
df525
2025 4 runner sr5
Wish you luck, that OEM light bar requires high beam to be "On" for it to work. So, I'm guessing it's powered from the factory headlight harness.
Dead Horse
Oklahoma
I'd put a sizeable wager on there being a 12v and ground that'll fire that puppy up. That's all I need to find. If I can get a factory connector to pin into, that would just be cake on top of my cake.
