Small Gaps in Fender Flares?
TRDBROG
NV
4R TRD PRO
Hi, anyone has these small gaps on the lower edges of the front fender flares?
Tiny rocks keep getting wedged in.
2025 2026 4runner 6th gen Small Gaps in Fender Flares? IMG_3259
yeah as noted above it started withe the tacoma and TRD Jon pointed it out on his.
just the adhesive not curing properly is my guess
Frcefed579
51st State (jk)
Wave Maker
My PPF guy removed my fender flares to ensure that the PPF went behind them. This will prevent them from rubbing the paint off and reducing the chance of rust.
We did the same thing with the rear hatch handle since the 5th gen was notorious for the same issue.
Moby
Moby
NJ
TRD OR Premium
Yes. Same with my trd orp. Toyota cheaping out
TRDBROG
TRDBROG
NV
4R TRD PRO
Great idea. Wish my PPF shop did the same, it was like pulling teeth negotiating price and details.
I don’t remember on my 5th gen, had a 16 ORP and a 17 taco TRD PRO.
Vincenzo
Southeast
Possibly broken attachment point. The attachment points on the flares are very very delicate. The only thing that broke when I changed my grille. I had two break when removing. Had to repair with epoxy
Frcefed579
51st State (jk)
Wave Maker
Yeah shops can be a little wary taking parts off that may seen unnecessary at the time.
If ever you do end getting it redone, just make sure to remove the wheel well lining to pop the flares off from the inside after removing the bolts.
The plastic brackets holding the plugs that go into the body were extremely fragile and will break off. Then it's glue gun and prayers to get it aligned properly. Luckily, I only had a few 😅.
Oddly enough, they never had any issues pulling off the 4th gen TRD Pro taco fenders.
We never removed the fenders off my 5th gen runners.
Here's an example of the 5th gen rear hatch issue that I've seen multiple times and mine with the fender removed.
2025 2026 4runner 6th gen Small Gaps in Fender Flares? Imag
2025 2026 4runner 6th gen Small Gaps in Fender Flares? 20250508_093113
2025 2026 4runner 6th gen Small Gaps in Fender Flares? 20250506_170806
TRDBROG
TRDBROG
NV
4R TRD PRO
thank you for posting this! I can see that white clip from the gap! Super helpful!
And that Matt PPF 🔥🔥🔥
