Whoops changing cabin air filter. What did I do?
DirkC
Dirk
Atlanta, GA
RAM 1500
When I was trying to change my cabin air filter, I accidentally knocked a tab off of the plastic box just below the air filter box. See picture. The two little tabs at the end of the arrow are where the attachment was. When it popped off, it went down into the area where the passenger air bag sits. So, 1) What is the box and what was the tab for? 2) Is this a critical issue? 3) How would I go about finding/retrieving the tab?
2025 2026 4runner 6th gen Whoops changing cabin air filter.  What did I do? 4Runner Below Cabin Air Filter with arro
horbit
DFW
I broke one of those off as well but was able to super glue it back on. It seemed brittle. You can take the kick panel off in the footwell and may be able to retrieve it. Or just don't worry about it.
don't worry about it, just don't go breaking anything else
one tab busting off will not allow anything to open or come apart.
you can stick yourself under the dash with an (8mm I think) socket and drop the blower
motor and check around up there with a borescope to confirm you haven't
'opened the case' so to speak if you want to be paranoid
ThatSickRIp
TSR
2026 4Runner SR5
The broken piece might make a new rattle sound, but it will blend it with all the other rattles 😅
