What size hitch drop (towing my motorcycle)
DannyvanDelft
Danny
Strongsville
2026 4Runner TRD ORP
Going to tow my motorcycle to the track come spring, what drop on the hitch should I get? I'm not lifted. ORP.
i picked this up from walmart, i think harbor frieght has it also
only need the 2in as your max tow is only rated at 6000 lbs and the 2in ball is rated up to 7500
i went this one as the lock mechanism for the ball is recessed inside the adjustable piece for security (you have to slide the adjustable part out to access the ball lock channel)
and no i am not in chicago, thats the vpn location reporting
edit : also the lock pins for the hitch are long enough for the new 4runner hitch reciever. using one to lock my back up light currently from diode dyanmics
2025 2026 4runner 6th gen What size hitch drop (towing my motorcycle) 1768231984977-cj
spike-1999
Dan
Wauconda, Illinois
‘23 Tacomo OR
those rhino colored ones look nice, wonder how long that color lasts ?
is it just painted or ???
Lamuncha
new england
What I have done is set the trailer on level ground, get the trailer frame as close to horizontal as possible back the truck to the trailer hitch take some measurements.
Not sure of your bike trailer configuration but the top of the frame is a good reference point to the ground. That dimension is also the pretty close to the distance the top of the ball will seat on the trailer hitch.
Measure the truck receiver and compare to get the rise or drop.
spike-1999
Dan
Wauconda, Illinois
‘23 Tacomo OR
I have the black one. It does not look like paint, more like it’s been anodized. In any case, scratches show raw metal.
Joey_Midnight
NJ
4runner ORP, GT4, BRZ
Gotta messure the trailer when flat. My car trailer needed a 6inch drop hitch to be level
what hole/setting are you guys using for a u-haul trailer on a 6in drop?
might have to pull a u-haul back from ga, not sure what size though 4x6, 5x8.
using this for a hitch, and it would be nice to get an idea to set the height before trying to figure out in the lot.
2025 2026 4runner 6th gen What size hitch drop (towing my motorcycle) 1774263566144-a3
willie2323
Arizona/California
Underground26Platinum
for me no hole setting, just did the math knowing what the car hauler receiver height is when level and knowing my hitch height then subtracting the difference. At present that is all I plan to tow (a classic back n forth Az to Cali) other than my bike rack.
