TxTrdPro
TxTrdPro
Seth
DFW, TX
2025 4Runner TRD PRO
Looks like a beast man! I was thinking about doing that to mine as well. How are you liking the wheel/tire set up?
Thanks. Overall really like the setup. Would one hundred percent do the front/rear level as I feel like the Pro looked a little underwhelming stock. My TRD Pro Taco sat higher by a fair bit than the 4Runner does.
The BFG K03’s handled the snow really well, we did 305/65/18’s and I honestly wish I had done a full 35x12.5x18 size instead. Would require trimming with the current kit from Wescott however. I did this size because it was the largest option without cutting.
Really like the way the factory wheels look so glad we stuck with them. The spacers help a lot with the look, recently took them off for a day and the 4Runner looked considerably less aggressive.
zgreen
Zach
Thanks Seth. Appreciate it. I'm definitely interested in a bit of a lift, but for me, I don't like the look of the vehicle when it is leveled out and much prefer the factory rake. Just need to figure that out!
TxTrdPro
TxTrdPro
Seth
DFW, TX
Gotcha. You can opt out on installing the top hat part of the kit on the front which will then maintain a factory rake. I’ve seen several with this setup and that will give you the look you want.
zgreen
Zach
Awesome, thanks for the advice! I'll see ho much longer I can get out of the OEM tires and then make it all happen.
Gator 22
2021 TRD Off Road
I know you did the Westcott lift right after you got the black one and can't compare ride quality but Since you guys have 2 Pro's can you tell me the difference in ride quality between the 2 before you did the same to the white one?
zgreen
Zach
I haven't done mine. Not sure I will be doing any sort of lift just yet. Just will be going up a tire size to 275 70r 18's when I need to replace the OEM's.
Gator 22
2021 TRD Off Road
What is the ride difference between the 2 on normal roads. Westcott says the ride is a little stiffer with their lift. Some on the forum say its the same as stock. I know the tires make a difference too but wondering what your opinion is.
Thanks
zgreen
Zach
Thanks
I haven't driven one with any lift, let alone the Westcott one yet. Also, I have the Pro, which has a different, adjustable suspension set up than the other 4Runners. If and when I am able to drive in one or get it done myself, I'll report back!
