Scrappopatamus
Scrappopatamus
Barry
Midway KY
I want to also throw a lift kit on. But even with the trd pro mud flaps, it sounds like my truck still kicks up rocks (on gravel road) into the side of the vehicle and onto the fenders.
Is this the case for you? Did the lift make this worse?
I wouldn’t think so. I went through a little tacky mud over the weekend and didn’t have it strewn down the side
Formidable
Bellevue, WA
2025 TRD Pro
On prior 4runner and Tacoma generations any additional lift such as this would cause vibrations on the highway supposedly due to the increased angle of the axles as they come out of the diff. Companies have fabricated diff bushings/bearings to accomodate for this (Such as east coast gear supply). Link below. Have you encountered any vibration problems on the highway or otherwise?
https://eastcoastgearsupply.com/c-1...__RJlV-aXN2hE2Hoxjg-bAvJcLoHjOfBN62kfn8ExOTay
papadop88
Los Angeles
2025 4Runner TRD Pro
I have an '18 Pro w/17K miles that's bone stock other than a Wescot collar lift. I may upsize the tires at some point.
Hey Scrapp, are you getting any kind of vibration now that it's been lifted? Also, how is the nose dive in the front...has it been eliminated or reduced drastically?
Formidable
Bellevue, WA
2025 TRD Pro
Any vibrations at highway speeds?
So far 551 Miles in a month. The only mods so far have been the Wescott Designs Full Preload Collar Lift Kit and the Toyota Info Screen Protector.
I've gone off the reservation with numerous mods on our ORP . I'll post some photos of it and a list of mods sometime this weekend. I'm enjoying both vehicles and prefer the Pro, although our ORP is growing on me.
T_Pomp
Anthony
Illinois
2025 TRD Off Road Premium
I’m curious if you have taken your rig out fully loaded with this leveling kit installed? I just purchased it and not questioning my purpose due to the fact that I’m worried about the rear end sagging when loaded with gear. I think I probably should’ve purchased the front spacer and installed the heavier duty coil in the back.
danimaldaisy
Dan
San Bernardino
6th gen trd sport
im not sure what’s going on with the collar kit when it comes to the trd pro but I sent a question to westscott. They said on a regular 4Runner the complete kit is exactly level but if I wanted some rake to only install the collar without spacer for a 2” lift instead of a 2.5.
honestly in my 5th gen’s I ran bilsteins at 2.5/1.5 and 3/2.
the magic number is at least an inch of rake. 4 adults and gear in the back it didn’t sag and took off-roading like a champ. I’d expect the same.
Scrappopatamus
Scrappopatamus
Barry
Midway KY
I've yet to load it down but guessing I'd have a little squat in the rear. If you're planning to hang a bunch of weight on your vehicle, I'd suggest replacing the struts and springs or replace the springs to cope with increased load. Hope this helps
Scrappopatamus
Scrappopatamus
Barry
Midway KY
Here's a photo of our TRD OFF ROAD Premium with Westcott Kit. Lifting this vehicle and changing the wheels transformed this vehicle. Changing the Ugly wheels actually seemed to change the color of the paint. I wasn't crazy about the color but was vetoed. I really like it now
2025 2026 4runner 6th gen Westcott Designs collar lift kit installed on TRD Pro IMG_0522
Ferretdude
2025 TRD Pro 4Runner (Mudbath)
Thank you for these pics as well. Very helpful. Rig is looking good.
Did they install the full kit in the front (i.e. 1" top hat and collar)? I suspect they did because it looks like a full 2" lift. As I expected, It's perfectly level but for me it gives it the optical illusion of a reverse rake. If you indeed installed both the top hat and collar, then that answers my question.
I will be only installing the collar in the front.
Thank you!
Same
Ferretdude
Papadap, I am with you with just installing the collars in the front and pucks in the rear especially with your larger tire set up. I know it will look great and give you the look and function you are going for. I have noticed on two Westscott YouTube installation videos (Tacoma & Land Cruiser) that they are installing the collars only on the front suspension with no top hats. I am surprised that WD is not offering a package that excludes the top hats. Maybe you will enspire them to do just that once you show us all what it looks like with the measurments. I assume that are not getting as many orders for the PRO and Trailhunter so possibly the R&D hasn't caught up with all of the other offerings from Toyota. I contacted WD to see if they would just sell the preload collars and pucks as a kit. Jason wants me to send them the measurements of my stock height, front and rear from hub center to wheel well to determine what components to get. I told him that it's for a 2025 TRD PRO 4Runner. I would think they should already know that information. No point in buying parts I don't want or need.
I spoke with Ty over the phone at WD and they told me I could not make an order without the top hat, sadly.
danimaldaisy
Dan
San Bernardino
6th gen trd sport
Time to swap out those street tires.
I swapped out my wheels and put on the new Tacoma trd off-road wheels but in all black. 285/70/17 and I still have the fox lift kit in the garage. It’s to hot outside so maybe fall or winter and it will be lifted.
Scrappopatamus
Scrappopatamus
Barry
Midway KY
this one belongs to my Girl Friend and she could care less with regards to the tires. Seems everyone is always complementing her on the vehicle and she’s noticed the differences over time after seeing stock vehicles at the dealer. If it starts and goes where she intends, all is well. I seldom drive it, so …. ..
T_Pomp
Anthony
Illinois
To follow up on this, I was out in CO for a week this past July, loaded for bear, and I did have a slight sag in the rear. I should have gone with the Dobinsons coils that were the next level above +110 lbs.
Scrappopatamus
Scrappopatamus
Barry
Midway KY
I installed a complete Dobinsons set-up on my LC250 after I did the PRO. I had already purchased a Westcott kit for the LC250 but changed my mind after taking delivery and doing some research on the internet and the Landcruiser forum. If I drove the 4Runner daily or more often, I would change it over to Dobinsons. Both of our 4Runners are running the Westcott kits. They definitely look better and I like the stance and handling when driving. Julie goes to the Feed Mill weekly in her ORP and I've notice it squats when loaded. Not terrible but definitely noticeable.
