Weight of rear seats = 150 lbs in Trailhunter
Barak
Albuquerque
2016 4Runner
150 lbs.
yep
At least in the Trailhunter.
No wonder the payload numbers are not impressive.
I took the rear seats out for a camping modification and to allow for more cargo area for gear, and thought to my self, holy sh*t, these things are heavy! Much more so than my previous gen 5 TRD offroad.
They are nice seats, but wondering how they compare to the other models weight-wise.
Barak
5th gen i think the 2nd row rear seats were around 85 lbs per section, so around 170 lbs i think.
another old post they weighed about 50 lbs per section x 2 without the hardware.
3rd row was like 100 lbs for the whole unit.
KarlG
Karl
Fairfax, Va
2025 Toyota 4Runner TRD Off Road Premium
150 lbs.
yep
Barak
Wow!
How much of a pain was it to get them out? I never have passengers so have thought about just removing them.
its not the removal that is the issue (its still really involved on the non HV models), its the jury rig to level the load floor after your remove them.
someone posted a thread on removing the 2nd row on here.
Barak
Barak
Albuquerque
2016 4Runner
Wow!
Not very hard. You need to pry off the plastic covers at the base of the seats in front and back, then disconnect the electric plug, then remove the four bolts (each side)
Honestly, the hardest part for me was wrestling those heavy things out of the car.
Yes, the floor is uneven, but with a foam pad to go beneath my fridge, and a few leveling blocks, that extra storage space is very welcome
Barak
oregonalex
Portland, Oregon, USA
1998 4Runner SR5, 2025 4Runner TRD Off-Road
Barak
Yep. I also disabled the rear seat warnings using Carista first. And plugged up the bolt holes with silicone 10mm plugs.
To cover the space, I bought a piece of Minicell T200 closed cell foam at foambymail.com, cut it to shape using electric turkey knife and my wife made a zippered cover for it from 500 denier coated cordura nylon bought at therainshed.com. The bottom has strategically placed Velcro hook strips to attach to the carpet below. It works great and the pad does not budge. It has a bit of an overhang to hide the carpet cutouts.
The foam is firm enough to span the holes and indentations, but has just a bit of a give so that items don't slide wildly on it. The textured cordura helps too.
We chose 1" thick foam to match the lip on the PIO rubber cargo mat, but I imagine thinner foam would work as well.
2025 2026 4runner 6th gen Weight of rear seats = 150 lbs in Trailhunter pad1
2025 2026 4runner 6th gen Weight of rear seats = 150 lbs in Trailhunter pad2
2025 2026 4runner 6th gen Weight of rear seats = 150 lbs in Trailhunter pad3
oregonalex
Version 2.0:
Items were still sliding on the original design pad, so we replaced the top panel of the cover with non-slip fabric. Now cargo does not slide on it no matter what. A worthwhile improvement. The look is essentially the same.
HurScu
David
holyoke massachusetts
2026 4Runner I-max
Is using Carista a necessary step? I’m thinking of removing the rear seats in my 2026 Traillhunter. What will happen if I remove them without disabling the rear seat warning with Carista first? I see conflicting information on this. Some seem to unplug the seats without issue and others suggest it is a problem. I’ll have to get Carista and see what I can do with it.
Thanks for any information on this.
I have my rear seats removed for months without disabling anything. No issues.
