Trouble with balancing tires
mick
mick
Utah
2025 6th gen 4Runner Off Road Premium, 2016 5th gen 4Runner SR5 Premium.
I bought a set of Nokian Outpost nAT's 275 70/18R less than a month ago. Discount mounted and balanced upon installation. I have since been back two more times for vibration in the steering wheel and noticing shaking/vibrations in the driver's seat and floor. Has anyone else experienced this with their Nokians? I still have a couple of weeks on the 30day exchange for them. I like how they perform other than the not balancing well.
sscarter
Steve
Massachusetts
2019 4Runner
Might not be balancing as the issue. Could be defective tire(s).
mick
mick
mick
Utah
That's what I have been thinking also. I'll probably end up ordering another set and cross fingers on both hands that they will not be defective.
Dr_Al
Alex
Rav4, Tundra
Back in the day when I was really into 4 wheeling a friend bought a set of mud tires. I forget the brand but one of them just wouldn't balance right. After going around and around the tire shop finally said the truth. The tire was made poorly. To avoid throwing a new tire away the mfg does a process called shaving. It's where they try to remove some of the rubber to make the tire round. The tire shop showed us by measuring the tread depth. A new tire should have the same depth all the way around but one of the tires it varied. It wasn't much and by just looking you wouldn't notice it.
Of course when removing rubber you now create an imbalance that needs to be made up with more weights. Usually it can be done and the buyer never knows. But in come cases weights can't compensate. Heavy mud tires, I assume, will make the problem worse than your Nokians but I bet it happens to every tire brand. I also suspect that most people would never notice or if they did do anything about it. So it's a win for the tire brand.
Derek
Atlanta
2007 4Runner Limited, 2022 Lexus GX 460
I haven't had the best experiences at Discount Tire. Did they try road force balancing the tires? If so, what numbers did they see? That should give you an idea of which tires may be defective. At my local Discount Tire, they apparently don't do road force unless you ask for it (not sure why) and even then I had a hard time convincing them a set of tires were defective. Fortunately you do have the 30 day exchange period which is what I did when they couldn't balance two sets of Michelin Defenders (not sure why people like them so much as I think they are well below average).
Gator 22
2021 TRD Off Road
I assume you are not running spacers.
did they rotate front to back?
rwuest
Robert
2026 Trailhunter, 2006 Trailblazer
Has anyone rotated their tires before to verify the behavior changes? I have a new set of Pirellis giving me grief at 70 MPH. They've been balanced twice (not road force balanced). I was think of doing a rotation on one side, test 'em, then do the other side and test, to see which tire is actually giving me grief. Google Gemini also says there is something to do with the roof rack that Toyota knows about and has a known bulletin/fix for it. From Gemini:
4. The Trailhunter Roof Rack Check
Interestingly, several owners of the new 4th-Gen Tacoma and 6th-Gen 4Runner Trailhunters have reported a mysterious "vibration and dynamic shimmy" that starts strictly around 65–70 MPH. In many cases, it wasn't the tires at all—it was the OEM ARB roof rack catching high-speed wind, causing the entire roof skin and chassis to resonate, which feels exactly like a tire vibration through the seat and steering column. [1, 2]
  • The Fix: Toyota has a known bulletin/fix for this where dealers remove the rack, apply specialized foam insulation dampening pads, and re-torque it to spec. To test this yourself, you can temporarily wrap the front crossbars of your rack in thick towels or painter's tape to alter the airflow and see if the 70 MPH shimmy changes. [1]
Gumpus
US
The most likely root cause is tire nonuniformity (ie road force variation or R1H).
Regular balance is easy so if you're having trouble return the tires for sure. Road force balance isn't really balance, doesn't always work, and if you need it it's because of marginal or poor tire quality.
mick
mick
mick
Utah
No wheel spacers, and stock TRD Offroad wheels. I'll be going in today to order a new set of tires. From what I have read people with these tires like them. The tire adventure continues, hopefully for the best.
this 6th gen seems to need road force balance more so than the 5th gen.
it also will show if the tire is bad internally if the road force is 26 lbs or higher
15-25 is acceptable for suv/trucks
anything above 15 for passenger cars is usually too much since they are more sensitive to higher loads
Gumpus
US
2 factors cause this vibration:
1. tire/wheel quality
2. vehicle sensitivity to tire/wheel quality
There's a lot of variation in vehicle sensitivity and how bad tires need to be to cause vibration problems. The numbers you quote as acceptable would be out of spec in my experience.
John2112
Austin Texas
I have those same tires, and they are awesome. Discount tire is not known for their expertise in balancing. I had a few vibrations with mine as well and while I was getting my free oil change from the dealer I got them to balance them and the problem was solved. You might do an online search for tire balancing near you and see if there's an off-road shop that takes the time to do a good job. Discount tire has good prices but balancing has always been an issue with them for me. On my old Jeep I had BF Goodrich ko2s and they never could balance them, the local off-road shop did and they got it right the first time. Those nokians are a lot better than the BF Goodrich, I would hang on to.
mick
mick
mick
Utah
Discount Tire finally resolved the balance issue, after the 4th try.
each person is different on what is acceptable on road force.
for me being under 25 was good enough for me. the problem i really have is ND and SD roads. the winds also factors in ND and SD.
once i got out of ND and SD, those same tires where night and day for vibrations. hardly anything.
in ND, i can see my passenger seat vibrate, but when i drove from ND thru SD and straight down i-29 to kansas city and then across st louis then down to nashville, chattanooga then ATL the tires hardly had an vibrations. same coming back up to ND and once i got in SD and ND, it came right back.
i blame it on the roads and constant winds up here.
as they say, montana blows and chicago sucks and we are the people stuck in the middle between them :ROFLMAO:
