TRD Off Road on TRD Pro Wheels
l27buick
jim
texas
2026 4runner
maybe we already have this info available but 275/70/18 Toyo at3 on trd pro wheels rub only on the mud flaps while turning. Figured I’d share this info to help someone else.
2025 2026 4runner 6th gen TRD Off Road on TRD Pro Wheels IMG_4902
2025 2026 4runner 6th gen TRD Off Road on TRD Pro Wheels IMG_4894
Dyingbreed
Alb NM
26 4RunnerTRD Off Road Premium, 25 Tacoma TRD Off Road
Good to know. That's the size I was planning on replacing the stock tires with.
l27buick
jim
texas
2026 4runner
Here is the poke. I did remove the mud flaps until I can find some flexible replacements because I do off road. Just building it up before I do. They are e rated and at 35 psi the bumps are amplified and they do make some noise. But the wife didn’t hate it so that’s a good thing. I plan to lift with replace the shocks and spring to soften the ride quality. Just gotta do research.
2025 2026 4runner 6th gen TRD Off Road on TRD Pro Wheels IMG_4898
2025 2026 4runner 6th gen TRD Off Road on TRD Pro Wheels IMG_4897
2025 2026 4runner 6th gen TRD Off Road on TRD Pro Wheels IMG_4896
2025 2026 4runner 6th gen TRD Off Road on TRD Pro Wheels IMG_4895
Joe Dirt
seems to be completely flush I'm wondering what the offset is on those Pro Wheels I was told they were a +20
4Runner8
Brian
2026 4Runner
There are two different mudflap sizes. The TRD Pro mud flaps have a slimmer profile to reduce the rubbing compared to the standard mud flaps offered on the non-Pro (possibly Trailhunter) models.
BonRunner
2026 TRD Sport Premium / WCP
I had the same issue. I got the TRD Pro OEM mud flaps that are wider & don't have the inner raised part, although they are expensive. You should get these generic wide mud flaps on Amazon, they are the same as wide mud flaps on Pro model for less than $60! Only difference is no "4RUNNER" text on rear flaps.
https://amzn.to/4gQiVtI
No rub after. Everything is smooth sailing!
2025 2026 4runner 6th gen TRD Off Road on TRD Pro Wheels 20260604_182206
2025 2026 4runner 6th gen TRD Off Road on TRD Pro Wheels 6G4R_Fall Colors_01
2025 2026 4runner 6th gen TRD Off Road on TRD Pro Wheels GridArt_20260831_104957998
l27buick
jim
texas
2026 4runner
I’m assuming they don’t flex for off roading ? I guess I can always take them off before hitting the trails.
JakeJoeBob
Jake
Tacoma
Can you drop the part numbers?
