Tire Suggestions? Off road tires that are also good on pavement
4RunnerJay
usa
Hello All,
I’m starting to look at some modifications.
Any suggestions on off road tires that are also good on pavement? I guess not as loud on the road.
Maybe not super heavy.
Thank you.
oregonalex
Portland, Oregon, USA
1998 4Runner SR5, 2025 4Runner TRD Off-Road
That brings up a question. Many people recommend Load C tires as a good compromise where Load E may be overkill and SL too fragile. In the size we are dealing with here - 265/70R18 there are precious few Load C tires at all. In fact, I only found one - a Goodyear Wrangler Enforcer AT intended for law enforcement vehicles. Is there anything else available?
4RunnerJay
usa
I think Toyo may have one, but I’ll have to look again. It might be an SL.
Powell, OH
Toyo makes two different Open County AT III's in 265/70R18, and they are both SL. The original equipment is marked "GA", and is basically a lighter, shallower tread depth version of the non "GA" version. The "GA" version has only 10.1/32" tread depth, weighs 39lbs, and carries an 116H rating. The non "GA" version is a 116T with 13.4/32" tread depth, and weighs 43lbs.
General makes a C load rated tire, the Grabber APT.
4RunnerJay
usa
I guess the SL isn’t the best off road 🤷🏼‍♂️
TrdProGirl84
Um, I definitely have E Rated and I honestly don’t notice a difference. I run my PSI at 33-35. If you want C Load get C Load.
chouser
craig
Denver
2025 Offroad hybrid
No it’s not. And if you have a TRD Pro you’ve got tires that are have tread life, literally. I removed them so fast along with changed my wheels, too
Get ya some Bridgestone Duellers. Love them.
BRunner
B
Stuff!
I suggest deciding what size you want to go with and start looking at all terrains in that size.
I currently have C load KO2's on my Wrangler in 35's, they ride worse than my D load 37 inch Cooper AT3 XLT's did and worse than my E load 35 Falken AT3W's did on my Jeeps.
A quality E load tire can ride very nice with the right air pressure. I've had E load AT3W's in 255/80r17 on my 2019 4Runner and they were great paired with Fox 2.0 suspension. I ran Toyo MT E load 255's on my 2018 Tacoma paired with Eibach suspension and they were great for an MT. What I'm getting at is get a quality tire and run proper air pressure. Do a chalk test to be sure you're getting proper contact across the entire tread.
As soon as my 2026 4Runner arrives I will be going to 255 E loads again without hesitation.
