The First Mod Every 6th Gen 4Runner Owner Should Consider: Double Your Usable Cargo Space
AmericanAdventureLab
James
St. George, UT
2025 4Runner, 2011 4Runner
Welcome
American Adventure Lab
www.AmericanAdventureLab.com
Phone: 385.202.4188 | Email: [email protected] | Instagram: @AmericanAdventureLab
https://americanadventurelab.com/product/6th-gen-4runner-mass-platform-non-hybrid/
One of the biggest challenges with any adventure vehicle is organizing cargo without sacrificing accessibility.
Whether you're carrying camping gear, recovery equipment, tools, refrigeration, or everyday cargo, the factory cargo area can quickly become cluttered and difficult to manage.
We wanted a solution that creates a strong, modular foundation for cargo management while maintaining access to the factory storage areas and requiring no permanent vehicle modifications.
The American Adventure Lab 6th Gen 4Runner MASS Platform is a modular cargo management system designed specifically for 2025+ Toyota 4Runner 2-row non-hybrid models. Built around the proven MASS (Modular Adaptable Storage System) architecture, the platform provides a configurable foundation for drawers, fridge slides, tie-downs, accessory mounts, and trail gear while maintaining a completely bolt-in installation.
Features & Benefits:
• Designed specifically for 2025+ Toyota 4Runner 2-row non-hybrid models
• MASS (Modular Adaptable Storage System) grid pattern
• Compatible with drawers, fridge slides, tie-downs, and accessory plates
• Aluminum deck construction for weight savings
• Steel mounting brackets for strength and rigidity
• Fully bolt-in installation
• No drilling required
• Uses factory mounting points
• Integrated access doors preserve under-platform storage
• Available with Fixed Access Doors or Removable (Latched) Access Doors
• Geometry designed specifically for the 6th Gen 4Runner cargo area
• Maintains factory trim clearances
• Compatible with MASS-pattern accessories
• Reversible installation can be returned to stock
• Available in Mil-Spec coating, Textured Black powder coat, or Raw/Unfinished finishes
• Made for adventure, overland, work, and daily-use applications
Choose Your Access Door Configuration:
Fixed Access Doors
• Compatible with American Adventure Lab accessory brackets inside the storage cavity
• Ideal for auxiliary battery and onboard air installations
• Rigid panel design
• Secured with hardware
• Recommended for permanent power and air system builds
• Quick-release latch design
• Fast access to factory storage areas
• Easy panel removal
• Ideal for users who frequently access under-platform storage
• Not compatible with American Adventure Lab accessory brackets inside the storage cavity due to latch clearance requirements
Compatible Accessories:
• MASS Storage Drawers
• MASS Fridge Slides
• Tie-Down Rings
• Universal Mounting Plates
• Air Connection Kit
• Accessory Trays
• Auxiliary Battery Mounts (Fixed Door version required)
Installation Notes:
• Designed for 2025+ Toyota 4Runner 2-row non-hybrid models
• Does not fit hybrid (i-FORCE MAX) models
• Does not fit 3-row models
• No cutting or drilling required
• Standard hand tools required
• Typical installation time is approximately 1–2 hours
• Fully reversible installation
• Installation instructions available through the American Adventure Lab Instructions Library
Frequently Asked Questions
Which 4Runner models does this fit?
This platform is designed specifically for 2025+ Toyota 4Runner 2-row non-hybrid models. It is not compatible with hybrid (i-FORCE MAX) or 3-row vehicles.
Do I need to drill or modify my vehicle?
No. The MASS Platform is a fully bolt-in system that utilizes factory mounting points. No cutting or drilling is required.
Can I install drawers or a fridge slide?
Yes. The MASS grid pattern is designed to support compatible drawers, fridge slides, tie-downs, and accessory mounts.
What's the difference between Fixed and Removable Access Doors?
Fixed doors are recommended for power and air system installations and support internal accessory brackets. Removable doors prioritize quick access to the factory storage area but cannot use internal accessory brackets due to latch clearance requirements.
Can I mount an auxiliary battery or onboard air system?
Yes. American Adventure Lab offers accessory trays, battery mounts, and air-system accessories designed to work with the MASS Platform. Auxiliary battery mounts require the Fixed Access Door configuration.
Can the platform be removed later?
Yes. The installation is fully reversible and can be returned to stock if desired.
If you're looking to create a more organized, modular, and adventure-ready cargo area in your 6th Gen 4Runner, the American Adventure Lab MASS Platform provides a strong foundation that can grow with your build while maintaining factory storage access and requiring no permanent modifications.
We're happy to answer any questions about fitment, access door options, accessory compatibility, or installation.
2025 2026 4runner 6th gen The First Mod Every 6th Gen 4Runner Owner Should Consider: Double Your Usable Cargo Space IMG_3860-1536x1151.jpg
2025 2026 4runner 6th gen The First Mod Every 6th Gen 4Runner Owner Should Consider: Double Your Usable Cargo Space Prototype-M-1536x1024
2025 2026 4runner 6th gen The First Mod Every 6th Gen 4Runner Owner Should Consider: Double Your Usable Cargo Space AAL-Toyota-Product-Testing-Camp-16-1536x1023.jpg
Snowball
2026 Toyota 4Runner
This is probably a stupid question, but this does not affect the ability to use the second row of seats correct?
It appears the seats are in their normal position in one of the photos, but in the other photos it looks like the platform/base plate of the system extends far enough that it would be under that row of seating.
I’m very interested in your system, the flexibility to choose the drawers and slides that fit a particular use case is great.
mfoga
Socal
r4unner
Very nice! Wish there was a hybrid version.
Sadly they need someone to give up a vehicle for like week to make them. they had been asking for volunteers and I was considering it until I found out the time frame.
Joe Dirt
For my two cents literally! I would just pull the two back seats out. Put the supplied latch caps on just to cover it up. Measure off a 3 ply plywood base and felt back it with some contact cement. Done!
go down to the depot get yourself some Milwaukee or HDX plastic containers. Use your tie down hooks in the bed that are supplied already. You're done and you have exceptional storage without the rear seats. You can even just remove the 60% side and cut your base to match that configuration.
And yes it's do it yourself but for my hard-earned money all I'm using it for is a base to put a bunch of stuff on. And I mean stuff like soil topping, fertilizer, bricks, occasional bags of cement, give it a good vacuum throw in my HDX storage containers with my camping gear and my little power station and I'm good to go for a weekend and I can sleep in the back. Oh and a couple of cans of beer spray! Just my two cents
lanadeldeathray
Seattle, WA
2026 Trailhunter
hmm....damn. Well I’d probably offer mine up in tribute but St George is too far.
Vincenzo
Southeast
Welcome
Fixed Access Doors
• Tie-Down Rings
• Accessory Trays
Installation Notes:
Can I order this without all of the extra tie down points? I would like just a tie down point in each corner.
mfoga
Socal
r4unner
I had some time and had considered going up there (still a days drive) for a few days get a rental to go ride mtn bikes but a week was more than I could do.
