Switching from Jeep - what lift / parts to get?
Uncle T
NV
4runner ORP
Hello all, I am new here and seeking advice from you all that forgot more than I will know. Coming from a built out Wrangler Rubicon. I am wanting to switch over to a 4runner mainly for the dependability and better on road driving. This vehicle will 95% be used a day hunting rig for Nevada and SE Oregon. Typical day will be 1 hour on pavement then 1 hour on dirt 30 of that being fairly crappy terrain. I have a GMC AT4X and haul a built out Polaris ranger for the really bad stuff.
I am looking for real world advice on what lift/parts to get. I want to run in the 34" range tire and want the best combo of on road and off road characteristics. I am not remotely interested in looks as this is purely something that will be used hard and put away wet from day one. I am thinking of going ORP and basically building from the ground up or is it better to go TRD PRO and add from there?
I am not super concerned about budget but don't really need to spend into the diminishing return abyss either. Also if anyone has suggestions on a very good shop within a couple of hour drive from Reno. Thank you in advance for the help.
I have ORP to which I've added all the steel Trailhunter skids and rock rails - and kind of wish I had a Trailhunter so I'd have the Sway Bar Disconnect (instead of having to manually disconnect the links for the really tough rock crawling).
But you do not need a lift to run 34s. There are many examples on this forum (see Bigger Wheels, lift kits, etc. to start) of 34s (e.g., 285/70R18 - 33.7" typical) fitting without lift.
I'm running 285/75R18s (34.8") with just a 1.25" level kit and the crash bar removed and it clears with the front fender liner pushed in and air dam tab bent out of the way. (Offset MATTERS here.)
Point is: you don't NEED to lift to fit 34s.
If you are going to add all the armor anyway, and appreciate the roof rack and snorkel - and SDM! - Trailhunter might be the way to go. But if you are set on a lift kit OR/ORP or even SR5 might be the right answer. (Note: the TRD OR/P Hybrids, PRO and THunter all (I believe) have a bigger diff and rear axle than the non-hybrid models. This might be a reason to go OR Hybrid or PRO/THunter.)
Side note: even though I have fit the bigger tires, I'm still busy researching suspension changes. I'm currently zeroed in on the OME MT64 2135 kit or a similar kit EMS kit from Dobinson's. But I may just keep my OR Bilstein's and upgrade the springs to get just a bit more height and ability to handle heavier loads (a bumper and winch is in my future, for example). The OR lives up to its name and is super capable and comfortable off road - all 4 wheels moving up and down over rocks and always in control with nary a rattle. (Note: Many complain that the suspension is stiff ("jittery") on road or on gravel which certainly can be addressed with aftermarket shocks like the ones I'm considering)
Hope this is the sort of insight you were looking for. Good luck with the choice.
Uncle T
NV
4runner ORP
Thanks Mike. Without question going the lift and best shock possible, not looking to pinch pennies. Ride over rough terrain is very important to me. How big a deal is the front swaybar disconnect on the 4runner suspension? Its a rather large issue coming from a straight axel.
Good question. Getting the large (22mm I think) bolt broken free took some work with 10" of pipe beyond the end of my 1/2" Craftsman ratchet (which is about a foot long itself). Just barely enough room under the vehicle to get the leverage needed. Spec is 159 #-ft. And I think it was past that. See photo below.
2025 2026 4runner 6th gen Switching from Jeep - what lift / parts to get? 20260417_175109
But after breaking it free and replacing it at 150 #-ft (the limit of my 2 foot long torque wrench), I was able to remove both connections in the field in <10 minutes. This shot is at the trailhead at an onX Black (7) trail where I wanted the additional articulation:
2025 2026 4runner 6th gen Switching from Jeep - what lift / parts to get? 20260418_093047
I was a little nervous leaving the link attached but it seemed that there was nothing for it to contact and I had no issue. But it was a pain and having a push button solution like I would have gotten with Trailhunter would be nice.
BUT.... since you are getting a 2026, you can get the Stabilizer Disconnect Mechanism (SDM) option on the TRD ORP Hybrid! So... maybe I've helped you pick your trim and options,
Speaking of options: I highly recommend the Tow Package (with digital rear view mirror) - this option has value WAY beyond the $400 on my sticker. Also the Auxiliary switches - also at $400 comes along with an alternator that doesn't appear without that option. This one is less critical but probably will come with an ORP that has SDM and Tow Tech.
Uncle T
NV
4runner ORP
Dang that seems like some work to do on the trail. I think I am going to shy away from the Trailhunter. I just really don't want the hybrid and the weight. If I could get it in gas it would be a done deal, even with the stupid snorkel noise. Thanks on the tow package will get that for sure. Just going to work around the switches with an spod or similar. It's the lift that is throwing me. I had a king setup on my jeep and it was ok. Not sure if Icon, OME, or Fox is the way to go on the Gen 6.
And I thought for sure I had you convinced for a Hybrid with its bigger rear diff:>) I like my hybrid a lot and their are some options that only come on Hybrid - SDM for example. Tow Tech and Aux switches you can get on gas models I believe. The weight is not a downside to me... the HP/Torque it adds way more than compensates and the vehicle can absolutely handle the weight. The main hybrid downside in my opinion is the loss of cargo space.
As for lifts - all of Icon, OME and Fox have good solutions. And there is also the Toyota TRD Lift option for $2999. Its not a bad choice - especially if comparing to the lower end aftermarket kits. Search the forum for lots of recent details on it. I'm leaning toward the OME MT64 kit but have a good shop nearby that wants me to consider Dobinson's. I'm still in research mode.
I'll look forward to hear what you do.
NotApplicable
WA, USA
4Runner, IONIQ 9, Sprinter
If I were doing a lift I'd do the TRD one. But it's not necessary unless required for the tire size you're targeting. And lifts are mostly cosmetic if they're not enabling a larger tire than is possible without the lift.
Coldwiz
Frank
Saukville Wisconsin
I think you answered this already as I was going to ask if you wanted to hybrid or non hybrid. That will determine what model you get. Sometimes I wish I had gone non hybrid for the simplicity of it but I do enjoy all the extra torque that comes with the hybrid. I'm pretty sure you can run 285/70r18s which are 34s on the stock suspension/stock wheels with no lift. I'm running OME MT64 shocks which lifted the front 1.75" on the lowest setting. Rear I have a 60mm spacer. Rides a tad better than stock I guess but small bump sensitivity is higher with the LT tires. Tires are 34x11.5r17 but spec at 33.5" according to Toyo. RRW RR7-S wheels +25 offset. I drive a lot and was trying to keep the unsprung weight down but probably should have kept the stock wheels and gone 285/70r18 myself.
2025 2026 4runner 6th gen Switching from Jeep - what lift / parts to get? 20260527_132939
Uncle T
NV
4runner ORP
Great looking rig! Yes I am not a fan of the hybrid at all. You lose approx 425# of payload and significant amount of area in the rear. I have 2 dog kennels in the back so that is a non starter in my case. I am going to be maxing out articulation pretty much on a weekly occasion. Really what I ultimately want is something that can get me to 80% of what my SXS can do but go 80 down the freeway in relative comfort. My rubicon could handle the off-road stuff great but they just suck on the freeway. Sorry to the jeep lovers, but I have had 2 different generations of the 4 doors over the past 12 years and they just do.
I was always under the impression that LT "flotation" (or numeric) tires were true to size so your comment made me wonder. But I checked the Toyo A/T III specs that I referenced when getting my A/T IIIs. Sure enough ALL the floatation tires (at least on the 17" and 18" wheel sizes that I checked) are 0.5" LESS in diameter than the first number (i.e., all the 35x(width)R's show diameter of 34.5"). I've been careful to always note that my 285/75R18s are 34.8" when I refer to them as "35s" but it turns out that my tires are actually 0.3" bigger in diameter than the same A/T III in a 35x12.5R18LT. Of course they are narrower at 11.3" but that is clear from the 285 mm metric number. (BTW - the 17" wheel spec sheet only lists one 34" size: 34x10.5R17)
My tires are also labeled with "OD: 35; OW: 11.50" (see photo) so I guess this tire size thing is all an approximation.
2025 2026 4runner 6th gen Switching from Jeep - what lift / parts to get? 20260315_105517-EDIT
I learn something new on this forum every day.
