Undefeatable
Kevin
Southern California
As someone with a SR5, it looks like I can only order the "Rally" version, not the "High Clearance" ones. I wonder if the "Rally" versions will work with the 285/70r17s that so many of us are running.
On the site, it says its made for stock or close to stock wheel setups, so I wonder if 33" tires are pushing it too far and will rub since the "Rally" ones mount on the inside of the wheel well.
NotApplicable
WA, USA
4Runner, IONIQ 9, Sprinter
Other ORP flaps I've looked at have the same fitments.
Something different about the body ?
The high clearance ones hug the outside of the flare. I guess this one is made for the standard flares, as is the standard rally ones
talmadge
talmadge
Timothy
SLC, UT
I believe the reason is the wider fender flares on the TRD Pro and Trailhunter models.
j41ruX
Jairo
Davenport FL. 33837
4Runner TRD Pro 2025 Honda Civic EX 2014
Not for me , I’m looking for a better design, don’t like the flat square shape
4Funnr
Brian
2025 4Runner TRD Pro
Why don't these companies send black screws and washers with their mudflaps? It is impossible to match seven different screws aftermarket.
josiahg52
Josiah
Maine, United States
They prioritize corrosion resistance, lower cost, supply chain simplicity, availability, etc. Personally, I'd rather good stainless hardware than hardware that will corrode.
