- First Name
- Matt
- Joined
- Mar 17, 2025
- Threads
- 7
- Messages
- 192
- Reaction score
- 123
- Location
- Hamilton, ON Canada
- Vehicle(s)
- 2025 4R
Yes you can.Brother, we’re on the same page
Can you fit one of the same in under as a spare? What do you figure the diff in km/h is with the 18s?
I think the speedometer was designed for 33 inch tires because the trd pro, trd off road, and trail hunter come with them.Ready for winter in Southern Ontario. Snow is expected on Sunday
Swapped factory 20" rims for these TRD PRO 265/70/18, thanks to @RADHAUS
No rubbing, and slight variance on speedometer
Would it not be modified for the limited/platinum with 20” stock?I think the speedometer was designed for 33 inch tires because the trd pro, trd off road, and trail hunter come with them.
not going to bother with the spare, so i wouldn't know. and the spare doesn't match the OEMs i will use for summer anyways. i don't mind the 20's for summer use, but i do really like these Pro 18's for winter.Brother, we’re on the same page
Final gear ratio is exactly the same across all trims.Would it not be modified for the limited/platinum with 20” stock?
Hey Matt,
I went the other way around. Bought 4Gen Tacoma rims and saved my TRD Pro rims from the salt and corrosion. Still 265/70R18 size.
You can edit your post instead of making another comment265/70/18 miss spell!
