Xhale760
Kris
San DIego
When I measured edge of the tire to the bottom part of the fender It was slightly under a 2 inch difference. Then when I talked to the shop that was installing it they also said 2 inches would be slightly higher than the back, probably not noticeable stopped but driving they said it would look higher. So just trusted them and went with 1.5" Now when I do the same measurement tire to fender the front is only 1/8" lower than the back.
I did the same thing in my garage about 2 weeks ago i got the same results as you. Which is why i was going to go for the 1.5 as well. Thanks for the input once my rims arrive i will get it lifted as well.
sphinx
UT
2025 4Runner ORP
What’s your wheel/tire measurements, if you don’t mind? Also the Falkens look great. I’m stuck in three way tie between the KO3, AT3/4 or the Bajas (not sure I actually need the Baja though).
How was the install on the sliders?
Rellims
Rellims
Sean
ORP - Underground
275/70R18, as far as this install goes, I had it done at a local shop (Mountain Yotas). Given that some of these were shipped without all the proper holes drilled I figured it would be worth the extra $$ to not run into a issue I may not have the tool for.
sphinx
UT
2025 4Runner ORP
Yeah, I had seen the options on their site for the pre-drills. Haven’t taken delivery of my ORP yet but I want to get under when I get to check before shelling out
Rellims
Rellims
Sean
ORP - Underground
Ordered mine before there was an option, glad they adjusted to the poor QC on this part.
surfcast_rig
Long Island
4Runner and old Jeeps
did you install the lift yourself? i need to level mine, ive been a 90's jeep guy curious how straightforward a small lift is versus all of the geometry of like a 4" lift currently on TJ.
Rellims
Rellims
Sean
ORP - Underground
I did not, had a local shop instal both the lift and the sliders.
