Interesting find on tire pressure
ThatSickRIp
TSR
VA
2026 4Runner SR5
So, there was a post here a while back that had an online calculator for setting your tire pressure for the tires size and load rating. It recommended 27 PSI for my 285 70 17. I have them at about 32.
Just now I was looking at my receipts folder for the 4R, and I noticed the tire installer receipt list 26 PSI as recommended pressure, so very close to the online calculator above.
Has anyone gone this low on their tire pressure, and if so how were the results?
josiahg52
Josiah
Maine, United States
The required tire pressure is determined by the size and expected load per the Tire Load and Inflation Tables published by the TRA. Or you can just use what the door sticker says. Instead of running 80 psi in the rear tires on my Ram 2500, I found that there is really no need for more than 60 psi, IIRC, based on the rear axle and payload rating. I reprogrammed the TPMS set points to 60psi front and 40psi rear. If the weight of your vehicle and tire size supports it, 26 or 27psi wouldn't phase me as long as it falls within the tire manufacturer's pressure range.
Dr_Al
Alex
Rav4, Tundra
Back in the day radial tires were suppose to be at 28 psi. Bias tires needed to be at 32 psi. Then the whole Firestone Ford Explorer thing happened. Lots of fingers got pointed and suddenly they changed it to 32 psi. Fuel economy improved and suddenly 28 psi went away. There was some nonsense about other reasons (vehicles being heavier) but in the end nobody wanted to take the blame for a tire failure because it got too hot from running at a low pressure.
The real reason for the Firestone problem was a manufacturing problem. I think it was compounded by tires that were unusually old for a new tire. Ford made it worse by recommending 26 psi to improve the ride. I always set my tire pressure after the garage swaps the summer/winter tires. I've seen them as high as 38 psi (which will wear the center of the tire quicker than the edges). I usually set them to around 30 psi. If I was to go lower I would check them after about 5k miles to make sure the edges aren't wearing faster than the center.
If I was going on a trip pulling a trailer or loaded down I would air them up to at least 32 to handle the extra weight. But for normal use 27 psi wouldn't bother me.
ThatSickRIp
TSR
VA
2026 4Runner SR5
Thanks fellas 🍻
I think Ill give it a shot and see how it rides. When we load up for trips/vacations, I can always put a few PSI in to be safe, though we never pull a trailer so should still be good to go.
morsk
NY
2026 SR5
Sorta tangential, but I was looking at my stock 245/70/17 Yokohamas yesterday inflated to ~33 and they looked kinda flat. Rides well though, but was wondering if I should pump them up to 36
I have seen that "kinda flat" look on quite a few vehicles, including others I have had (so I know the pressure was to spec). My guess is that going by looks is not a good idea--just go by the recommended pressure and it should be good.
Skrr1225
If your 285s are SL tires, online load calculators commonly output roughly 26–27 PSI to match the original factory load capability. Running them at 32 PSI may feel noticeably stiffer or slightly over-inflated for daily pavement use.
ThatSickRIp
TSR
VA
2026 4Runner SR5
I think I'll drop to 28 and see how it feels and go from there.
Joey_Midnight
NJ
4runner ORP, GT4, BRZ
Been running my nitto g3 285s at 30 psi, ride was smoother and the mpg almost seemed to improve. Considering the outter edge blocks are closer and more stable then the center tread blocks on this tire, putting the load the edge may improve economy at a lower pressure
LP4Runner
Larry
2026 4Runner 4WD TRD Off-Rd Prem & 2026 4Runner 4WD TRD Off-Rd Prem iForce Max
Instead of guessing or wondering what psi you should be running day to day, get yourself a tire tread depth gauge. Check the depth across the tire, maybe on a monthly basis. Of course, going off road will often require lowering the psi, but that is temporary. For me, the factory recommended pressure on the door frame works with stock tires.
Virtual-Chris
Vancouver, BC
2027 4Runner
The best way I’ve found to get tire pressures optimized is the chalk test. You can find lots of videos on YouTube but the jist is to start at what you know is probably a bit over pressure so only the center of the tread is making contact with the road, cover a cross-section of your tread with chalk, drive a bit and check if the tire is making full contact with the road, and then deflate slightly and reassess… deflate a bit more if necessary, repeat until your full tread is making contact with the road… (all the chalk is gone)… that’s your ideal pressure.
this is more revelent as you go up in tire load range. as you get into "C" and "E" load tires, chalk test is a better measure than just going by the psi on the door jam.
but do take into account summer temps vs winter temps, especially in northern tier states.
i had mine set at 35 psi at 70F but this morning they are 31 psi at 37F and nothing has changed except ambient temp.
i 99% of the time only run SL tires, never had a need for "C/D/E" load tires since i started driving in '83
right now i run defender ltx ms2 in XL load but that is the standard for those tires, you cant find a SL load in that model of tire.
SL load tire are usually rated for max psi of 36 where as XL is rated up to 42 psi (usually)
Load Range and Ply Rating
Load RangePly RatingMax Load Carrying Air Pressure
Standard Load (SL)4@ 36 PSI
Extra Load (XL)4@ 42 PSI
C16@ 50 PSI
C26@ 35 PSI
D18@ 65 PSI
D28@ 50 PSI
E110@ 80 PSI
E210@ 65 PSI
F112@ 95 PSI
G14@ 110 PSI
Load Index and Carrying Capacity Table
Load IndexCarrying Capacity (lbs)
099
1102
2105
3107
4110
5114
6117
7120
8123
9128
10132
11136
12139
13143
14148
15152
16157
17161
18165
19171
20176
21182
22187
23193
24198
25204
26209
27215
28220
29227
30234
31240
32247
33254
34260
35267
36276
37282
38291
39300
40309
41320
42331
43342
44353
45364
46375
47386
48397
49408
50419
51430
52441
53454
54467
55481
56494
57507
58520
59536
60551
61567
62584
63600
64617
65639
66639
67677
68694
69716
70739
71761
72783
73805
74827
75852
76882
77908
78937
79963
80992
811019
821047
831074
841102
851135
861168
871201
881235
891279
901323
911356
921389
931433
941477
951521
961565
971609
981653
991709
1001764
1011819
1021874
1031929
1041984
1052039
1062094
1072149
1082205
1092271
1102337
1112403
1122469
1132535
1142601
1152679
1162756
1172833
1182910
1192998
1203086
1213197
1223307
1233417
1243527
1253638
1263748
1273858
1283968
1294079
1304189
1314289
1324409
1334541
1344674
1354806
1364938
1375071
1385203
1395357
1405512
1415677
1425842
1436008
1446173
1456393
1466614
1476779
1486844
1497165
1507385
