Gauge Cluster Plastic Screen / Window / Lens Replacement
toyota plastic cover over the MID screen has always been an issue and not just the 4R. my 2014 limited screen was easily scratched even with a brand new microfiber cloth that was never used out of the package.
even rubbing it with your finger can scratch it.
on the protech screen protector, over do it with the application bottle fluid when installing it. too much is just enough and barely at that. learned the hard way on the 23 tundra and i was lucky i bought the 2nd set kit add on for $15
elecfuyu
6G Platinum
damn, I have heart attach just looking at that picture. Hope you get it resolved soon.
TyRoosevelt
Tyler
maybe 10-15 minutes
You removed your cluster in 15 minutes? Which trim pieces did you remove? Someone posted earlier in the thread that you had to remove the majority of the interior so I was hoping we could help the OP. Thanks,
TRDBROG
TRDBROG
NV
4R TRD PRO
You are correct, it’s not the arm rest it’s the assembly around the shifter, #2 “console box assembly” is required for removal. Here is also the quote from Toyota to do the replacement.
Super helpful
maybe 10-15 minutes
Please elaborate on this, diagram shown earlier shows lots of work to remove it
TRDBROG
TRDBROG
NV
4R TRD PRO
Remove the head unit
Remove the long trim piece
Lower the steeringwheel
Remove the left air vent
Remove cluster
Thanks, 10-15 minutes. Do you dismantle dashes as a hobby?😂
TRDBROG
TRDBROG
NV
4R TRD PRO
#144 of my build page
Cluster
Seen your build, it’s great. Not doubting you. Just saying some of us are more mechanically inclined than others, and I am fairly handy.
Deejayp11
Peter
San Diego
2026 4Runner
Reviving this thread, did you ever end up replacing the Combination Meter Glass (#83852-35V00)? I ended up hating the screen protech HD film, I don't have a good opening to remove it. I know there are ways, but now I'm considering just replacing the plastic lens entirely if it's doable. I'm sure when I remove the screen protech film there will be residue left behind.
