Front parking sensor connector repair
milsuper
VA
TRD Off-Road Premiun
using the website i did find the parking sensor one
Wow...I did not expect that connector with pigtail wires would be that expensive....then you also have to splice/solder the wires for extra work. It comes with same color wires (looks like all black wires without color code on the photo at lower left corner)...WTH???
If I had to do the repair for OP's problem, I would simply replace the whole OEM wiring harness and just be done with... Not enough $ cost delta advantage for the extra work involved (to worth the repair of just one single damaged connector)...at least for me. YMMV.
Mman611
Michael
Ansonia, CT
2006 Subaru STi, 2019 Lexus IS300 RWD, 1995 BMW M3 (track toy), 2021 KTM Duke 39
When you find out the whole OE harness is multiple thousands of dollars, $90 doesn’t seem so bad
Mman611
Michael
Ansonia, CT
I actually just night the harness for $100
Yes sometimes you can get just a bumper harness and sometimes you need a whole front end harness. If OP doesn’t want to slice the wires in, contact your local Toyota parts department with your vin. They can check
