Fog Light Recommendations
Here is the Baja Designs light.
Did u get the Baja Fog kit that has their own brackets & purchase the WD brackets separately? Or did u get the S2 SAE fogs then attach to WD brackets?
If the lather option, which wiring adapter to make the S2 fog work with OEM wiring?
Appreciate it all the info!
KD2MYW
Phil
NYC
And the Rigid fogs on the Trailhunter go from white to yellow. They aren’t amber so they do look kinda weird as they looks very different from the amber drls. I know the yellow is better in bad weather but it looks off to me.
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
I bought the BD lights and it came with its own bracket, but I separately purchased the WD bracket. I was having some other installation work done at the time and so I had that shop install them. So not sure about the wiring adapter. But the BD lights have a specific TRD Pro/TH version of the light so I assume it was plug and play.
https://www.bajadesigns.com/product...-4runner-note-trd-pro-trailhunter/?vid=177271
Sleepy808
Hawaii
2025 Underground Pro
Hi so I have a TRD Pro and the connectors on the fogs are completely different from the non pro/th 4runner. Its a canbus connector of some kind so I can see why aftermarket ones arent compatible. I ended up replacing my OEM fogs with rigid amber pros. They work great and have a nice clean cutoff since they are SAE. They are not as orange as the DRL lights however if thats what youre looking for. Also, I had to hook them up using one my AUX harnesses the truck came with. Simple install. Hardest part was remvoing the bumper.
2025 2026 4runner 6th gen Fog Light Recommendations IMG_3830
2025 2026 4runner 6th gen Fog Light Recommendations IMG_3382
2025 2026 4runner 6th gen Fog Light Recommendations IMG_3395
2025 2026 4runner 6th gen Fog Light Recommendations IMG_3384
