Factory 7 inch Screen Upgrade - Cartrimhome C12 14 inch
FourWalker
MA
2025 4Runner TRD Off-Road
Hi everyone, I wanted to share my experience upgrading my factory screen from the 7 inch non-premium screen to the Cartrimhome 14 inch C12 display. This is the 12 gb/256 gb version. Overall, it was a fairly straightforward installation, but the instruction video that is provided is for a 4th gen Toyota Tacoma so it doesn’t match up perfectly with the way you would need to install it on the 6th gen 4Runner. I was able to take some photos of the install to make it easier for anyone else who is thinking about installing this in their non-premium trim 6th gen 4Runner. I ended up only using three of the wiring harnesses that they provided, and I believe they provided about 7 or 8. Attached is a photo of the ones I DID NOT use on the passenger seat of the vehicle. The primary wiring harness has a label on it that says 2025 Camry, and that is the one that fits my vehicle, not the one labeled LC300. They also provide a harness that has a number of different red, white and yellow connectors, but I believe that is one for people who have an aftermarket amplifier, subwoofer, or the factory JBL soundļæ¼ system. The unit I purchased came with a front facing camera, but I did not install it. I had some difficulty figuring out how to wire it, and will reach out to the vendor for clarity. Will also reach out about a thin pink line that appears on the right edge of the screen in reverse. Final warning, don’t connect the male connector with one black and one gray wire with the female connector that appears to match. Ask me how I know šŸ˜„. Overall, a worthy upgrade, in my opinion, and wanted to share with anyone else who would like to upgrade their factory 7 inch screen.
update: front camera wiring (see last photo) - To wire the front camera, attach the jbl harness (this is what I’m calling the one with all the RCA inputs), run the yellow CVBS-IN cable to the yellow connector on the camera wiring, insert the ā€œcamera powerā€ wire (from the harness that has the CAM VIN yellow RCA cable) to the black receiver on the camera wiring, then attach the CAM VIN to the CAM/VIDEO OUT coming from the Video Converter. If you don’t have an upgraded sound system and are not running any additional cameras, you don’t need to connect the jbl harness at all.
2025 2026 4runner 6th gen Factory 7 inch Screen Upgrade - Cartrimhome C12 14 inch IMG_5207
2025 2026 4runner 6th gen Factory 7 inch Screen Upgrade - Cartrimhome C12 14 inch IMG_5206
2025 2026 4runner 6th gen Factory 7 inch Screen Upgrade - Cartrimhome C12 14 inch IMG_5208
2025 2026 4runner 6th gen Factory 7 inch Screen Upgrade - Cartrimhome C12 14 inch IMG_5209
2025 2026 4runner 6th gen Factory 7 inch Screen Upgrade - Cartrimhome C12 14 inch IMG_5195
2025 2026 4runner 6th gen Factory 7 inch Screen Upgrade - Cartrimhome C12 14 inch IMG_5198
2025 2026 4runner 6th gen Factory 7 inch Screen Upgrade - Cartrimhome C12 14 inch IMG_5245
SNDR
New Hampshire
2022 Tacoma TRD Pro, 2026 4Runner ORP MAX (on order)
Looks good! Any improvement on sound quality?
df525
2025 4 runner sr5
they have a version with "360 camera". does that mean it can add additional cameras.
FourWalker
FourWalker
MA
Nah, it’s about the same. They did include extra connectors if wiring aftermarket sound or the factory jbl system.
FourWalker
FourWalker
MA
The one I bought came with a front facing camera so I’m assuming they include that plus 2 side cams in the kit you are looking at. Would suggest emailing them. They’re pretty responsive.
bigbruse
robbie
va
Still holding up well ? All factory steering wheel functions work correct?
