- Thread starter
- #1
I took my OFP Hybrid in for service not too long ago. First service at 8000km and I am noticing that the hybrid system doesn't kick on as often as it used to when I was driving around in the summer time. Normally the battery would kick on at a stop light, or while in drivethru's, but it seems like the engine is running a lot longer without going into battery. Even when approaching stop signs or stop lights, the regenerative braking usually puts the vehicle into hybrid battery mode when slowing down, and you can hear the whining of the charge when slowing down. It rarely does this anymore.
Does this happen with colder weather, ie under 10C? I know if features like AC or Heating can force the car engine to kick back on to charge the battery, but the battery indicator used to go up and down very frequently before, where now it stays charged around 80% with minimal switch over. I tried turning things off (heat, fans, etc) to test, but am not seeing any change or results when doing so.
I know there are a bunch of variables to dictate whether the system comes on or not. The amount of throttle given, the speed, the length of cruising the vehicle, during regenerative braking etc. I am just 100% sure the hybrid system is coming on less frequently now, and not sure if it was a coincidence due to the service I had from dealership (Service Level 1) at 8k.
Is this something I should approach the dealership with this info? Could they have programmed it this way or tuned it in a way that would affect the frequency of it kicking in?
In the manual (Page 70) states:
Conditions in which the gasoline engine may not stop
- When the “TOW HAUL” switch is on
- When the “MTS” switch is on
- Vehicles with part-time 4WD: When the front-wheel drive control switch is in “4H” or “4L”
- When the front-wheel drive control switch is in “4H” or “4L”
- Vehicles with full-time 4WD: When the front-wheel drive control switch is in “H4L” or “L4L”
- When braking (regenerative braking)
- When the hood is opened during "READY” indicator is illuminated
- When repeatedly accelerating/decelerating rapidly
- When repeatedly operating the hybrid system for a long time
- When driving down a long slope
I'm still under the impression that the system is not switching as much as it used to.
Would love to know if you've experienced this or not.
Thanks.
Thanks.
