Did you install your own roof rack or have a shop do it? Labor question
ThatSickRIp
TSR
VA
2026 4Runner SR5
Was curious to see how many here have installed their own roof racks, time/labor involved, etc.
I got a quote from a local shop and they want $467.97 (3 hrs) for the instal for a Wescott lo pro rack.
The shop has a great reputation and hear they do good work. Was wondering if thats in line with other areas
ChasingTrail
Taryn
Ozarks
My husband, who's extremely mechanically inclined, did mine and said it was easy. Like another comment said, removing the old one was the annoyance.
However, he also installed a RTT a couple days later, and THAT is a serious pain. Because of just how low-profile this rack is, maneuvering brackets/mounts etc underneath is seriously challenging. Just something to be aware of.
n1comedes
San Diego
Toyota 4Runner
I installed my sherpa capitol roof rack by myself. Fairly easy, just a bunch of nuts and bolts and repeat. Like everyone said, its the removal of the old rack that was annoying. Highly suggest getting an auto trim removal kit, makes it way much easier without the possibility of scratching or denting your roof with a flat screwdriver
tpmacleod
Tim
Vancouver, BC
2026 TRD Pro / 2014 Limited
I agree with this completely. I did my own Westcott Pro and since it sits so tight to the roof you really have to position it correctly for it not to sit on the frame. I was worried I did something wrong at first. I would suggest two people do the job and cover your roof so you don’t get accidental scratches.
mfoga
Socal
r4unner
The RTT the first time was a lot of work but that was a lot getting things lined up exactly where you want.
Now I have where I can install and remove well under 30min. That being said I did insane amount of searching for the best possible mounts to allow it be be as easy as possible before I started at all.
ThatSickRIp
TSR
VA
2026 4Runner SR5
No RTT plans, so good to go lol
ThatSickRIp
TSR
VA
2026 4Runner SR5
I had a shop do it. While I do most mods on my own being a solo modder I didn't want to risk dropping the rack on the roof.
One of my concerns as well
ThatSickRIp
TSR
VA
2026 4Runner SR5
Good to go auto trim removal kits (y)
ThatSickRIp
TSR
VA
2026 4Runner SR5
So has anyone tried installing one by installing the side rails first individually, and then installing the crossbars once the side rails are mounted? Id imagine that would make it way easier to install solo, but Im not sure if its possible since all the install videos show building the rack and then setting it on the roof.
ToYoDaMan
Allan
Bay Area
That sounds like a good price. In California., it's triple that amount .
n1comedes
San Diego
Toyota 4Runner
That’s pretty much what i did when I installed it on the roof by myself. Its just a pain having to go back and forth from one side to the other. But it saves you from having to call a friend and lifting one heavy piece than one small light piece at a time
mfoga
Socal
r4unner
I did not put all the rails but only a few, enough to hold its shape. I did have help to lift it on. I put folder up towels at the four corners to hold up and then would remove folds as I got it more in place and where I wanted it height wise. Then put the rest of the rails in.
3rdRunner
Bill
I had a shop do it- big mistake. They installed the front brackets incorrectly and in the wrong configuration. I ended up having to tear it down and redo it. Was trying to save time but ended up losing time and money on the deal. Lesson learned. You can definitely do it yourself. There are plenty of resources online. Just be patient.
