Cold air when AC is off?
Minnesota4Runner
Woodbury, MN
2025 TRD Sport
Our 2025 still blows cold air if the AC button is not lit and the vent system is turned on.
Probably normal but wondered if anybody knew the details.
PdlMnk
6G4R - TRD ORP Premium Hybrid
That's because you have it on auto, it decides when to turn the a/c on and off, but as you probably noticed, it's blowing cold air because it's summer.
Tarekith
Upper Left US
4Runner ORP & ‘22 Tacoma OR
It doesn’t always display auto when the temp is higher than your setting. It’s in the manual too.
bakutheleo
2025 4Runner i-Force Max
There is a setting you can configure to disable a/c on auto. I did that, as I want more control over when a/c runs. Set that to see if that changes the behavior.
LLL1990
United States
Toyota Camry and Ford F-150
Auto is displayed when in that setting. It is not in auto.
Anytime you manually override any function (like manually changing the fan speed) the "Auto" light turns off because the system isn't in full control. However all other functions will still be automatically controlled like the A/C. Secondly, setting the temperature to "LO" will automatically engage the A/C because "LO" is the systems lowest temperature output, meaning as cold as it can get.
