Anybody know of where a 12v ignition signal is in the back of a TRD ORP Hybrid?
PdlMnk
6G4R - TRD ORP Premium Hybrid
Long story short, hooking up the OEM compressor. It requires a 12v ignition signal to allow it to power on. I can't easily find one in the rear area. I know I could run a wire to the front, but I really want to avoid that, if possible.
I tried looking around the web, but no luck.
Vincenzo
Southeast
You have 12 volts at the trailer harness. You also have running lights that could also be of use if you are just looking for a signal
calvincartier
Calvin
West Hollywood, CA
I’m not 100 pct sure but if you pop/open that wheel well area there may be a 12V connector there.
PdlMnk
I found one in the fuse box under the glove box. Luckily, it's an empty slot with blades in it. I'll post more once I hve it complete. but it's 104F today, so It's not happening today.
