Any issues or resetting for disconnecting the battery?
Yoli
Yoli
Portland, OR
2026 4Runner ORP, 2007 4Runner Ltd
I plan on disconnecting the battery to get to the wiring harness going through the firewall for some power wire fed to the back (see my other threads). I'm wondering if there's any problems with systems that need intialization afterwards? I know in my 4th gen, the windows and the sunroof had to be recalibrated, but even after reading the manual, I just want to see what your experience has been like.
What about using a memory saver? It's a 9v battery that plugs into the OBD2 port to keep memory to critical systems. I didn't see anything on the forums about it, but maybe someone has used that before.
JasonIsLost
Jason
Atlanta
I disconnected my battery to install the Pro grille and haven't had any issues since.
if you read the manual, there is a section on what needs to be re-initialized after replacing the 12v battery
Yoli
Yoli
Yoli
Portland, OR
Yup, like I mentioned, I read it - but we all know that not everything is documented as it should be and user experiences sometimes bring up interesting problems. :) I was also curious if anyone has used the "memory saver" device I mentioned. I was able to do the work I needed without disconnecting the battery, but I am still wondering about that device for future work.
the biggest issue can see that is not documented is the engine/transmission and some other drivability things that are reset back to baseline when the 12v battery is pulled.
like how the transmission and engine response is learned over time
the other stuff in the manual is the usually the PDI stuff that needs to be done before a customer takes delivery.
