Any aftermarket fuel tanks?
yeah until you see the price for aftermarket tanks. probably be $1500-$2500 for one
probably leaning more toward to be above $2000 for an extended tank
Dead Horse
Oklahoma
I scoffed at the price of bigger gas tanks back around 2013-2014 after I bought my Tundra and hated that the light came on around 240-260 miles due to the 12.9ish MPG and tank size. Fast forward 12 years and I'm mad at 2014 Dead Horse for not buying one, because the range is by far my biggest complaint about my Tundra and has been since the day I bought it.
I try to not repeat my mistakes and would legit buy a bigger tank without a second thought if my range is consistently under 300 LOL
Icculus
Adam
NC
2025 IC Trailhunter
As far as I'm aware the only answer is whenever Long Range America comes out with a fit for the 6th gen and if anything like previous versions you'll also need a rear bumber/swing or something to relocate the spare tire.
Clonetrooper
Francis
Southern California
2025 4R Trailhunter, 2025 Lexus GX 550 OT+, 2018 Tesla X, 2016 Tundra CM
ouch $2300 for extra 18 gallons and you lose around 135lbs of capacity.
18 gal x 6 lbs each (or 6.3 gal, depends who you look up) + 25 lbs for the tank = 133 lbs
its already a low carrying capacity as it is and you lose another 135 lbs.
you are barely going to fit 4 people at 190 lbs a piece not including anything extra like luggage
and thats using a platinum at 895 lbs of capacity bone stock (you lose more if you add too many accessories)
start adding in off road gear, protection and what not and you are barely going to get 2 people and some gear carrying capacity
forgot to add ... how does adding another 135 lbs in the back affect steering at highway speeds ? does it lighten the front end too much?
