Turbo8
Las Vegas
Apparently you will be able to get an "Overlook Package" as an option, for only $12,452 (installation not included), you get the following:
  • Toyota Roof Rack by ARB
  • All-Weather Cargo Mat
  • TRD Front Skid Plate: Aluminum
  • Rear Differential Skid Plate
  • Transmission Skid Plate
  • Side Storage Multi Tool
  • Illuminated Front Emblem: Chrome
  • Body Side Molding
  • Door Panel Scuff Protectors
  • Mudguards
  • TRD 18-In. Wheel: Black (Includes 4 Wheels)
  • Badge Inserts: Bronze
  • Oval Tube Steps: Black
  • TRD Suspension Lift Kit (Coming Soon)
  • Pelican 140R Pelican Cargo Case
  • Yakima RoadShower Portable Pressurized Water Storage
  • ARB Premium Recovery Kit
  • Kammok Crosswing: 5'
  • Kammok Crosswing Single Panel 5'
  • Pelican 45QT Elite Wheeled Cooler: Tan
  • ARB Cargo Organizer
  • Factor 55™ Baja Vehicle Recovery Kit
    You can add it to your build on the Toyota site now.
    2025 2026 4runner 6th gen Overlook Package ordering available for 2026 4Runner 1775680379408-3c
  • Body Side Molding
  • Mudguards
yeah the bold i emphasized on the things you have to install, the rest is either FIO/PIO
gvan1998
MD
How much lift will you get from trd lift kit? I saw trd lift kit for tacomas gives a 2.5inches but the difference between a factory off road and trd.pro is only 1 inch
trd pro already has 1in of height from the factory over the other trims. adding the lift kit doesnt really give you much more over the factory height already for the cost ratio.
you would at most get an extra 1in of height on the lift kit for the front and 1in in the back on the trd pro
someone will have to verify that you only add 1in on the already 1in over the normal trims the trd pro has
gvan1998
MD
So my question is if you have an offroard, does the trd susp gives you a inch lift or 2.5inch lift.
prob 2 in at most once it settles.
gvan1998
MD
I have a TRD Pro. It sits 1inch higher than all the other trims. Nothing more stock
I understand that and thats what I see, but the other guys said that the trd susp should net you a 2 to 2.5 inch lift over stock offroad.
if you install the toyota lift kit (which btw is forthcoming) and its probably going to be like the tacoma lift kit you can add during PIO or have the dealer install it afterwards, you can replace the oem setup and gain 2.5 in on the non TRD Pro/Trailhunters.
since the TRD Pro and Trailhunter stock suspension is already 1in taller than the other trims, if you add the lift kit (and which is probably going to replace the stock suspension, not add to it) you are really only going to add 1in to 1.5 in to the suspension since the stock is already 1in taller.
see below the tacoma lift kit and btw the kit costs $3400
2025 2026 4runner 6th gen Overlook Package ordering available for 2026 4Runner 1775785505473-y0
gvan1998
MD
So the TRD Suspension upgrade kit is different from what TRD Pro comes stock.
correct, its a replacement kit for those that want more lift than stock on any trim (except for probably the limited and platinum due to avs system)
you get a better bang for the buck on the non TRD Pro/Trailhunters since you get 3in on the front and 2in on the rear vs the TRD Pro/Trailhunter where you lose 1in since the stock suspension is already 1in taller. so when you replace the TRD Pro/Trailhunter oem suspension you really only gain 2in front and 1in rear so to speak
TrdProGirl84
are you asking about the TRD Pro FOX OEM Suspension or the FOX Suspension that you can purchase?
yes
