VB4Runner
Mitesh
VA
2025 TRD ORP
Getting ready to spend the anniversary weekend in the mountains next week, so have been knocking things off the to-do list. A few things I got done this week:
  • Installed Meso Customs LED map and dome lights
  • Installed red rear recovery hook
  • Installed LAMTTO 360-deg 4-channel dash cam
  • Installed Racksbrax HD quick-release awning mounts
2025 2026 4runner 6th gen Installed: Meso Customs Map Dome Lights, red rear recovery hook, LAMTTO 360-deg 4-channel dash cam, Racksbrax HD quick release awning mounts IMG_7027
2025 2026 4runner 6th gen Installed: Meso Customs Map Dome Lights, red rear recovery hook, LAMTTO 360-deg 4-channel dash cam, Racksbrax HD quick release awning mounts IMG_7026
2025 2026 4runner 6th gen Installed: Meso Customs Map Dome Lights, red rear recovery hook, LAMTTO 360-deg 4-channel dash cam, Racksbrax HD quick release awning mounts IMG_7020
2025 2026 4runner 6th gen Installed: Meso Customs Map Dome Lights, red rear recovery hook, LAMTTO 360-deg 4-channel dash cam, Racksbrax HD quick release awning mounts IMG_7023
2025 2026 4runner 6th gen Installed: Meso Customs Map Dome Lights, red rear recovery hook, LAMTTO 360-deg 4-channel dash cam, Racksbrax HD quick release awning mounts IMG_7028
2025 2026 4runner 6th gen Installed: Meso Customs Map Dome Lights, red rear recovery hook, LAMTTO 360-deg 4-channel dash cam, Racksbrax HD quick release awning mounts IMG_7019
renz244
Looks sick! I just purchased meso customs dome and map lights. I plan to install them this week. The YouTube installation guide says you have to drill into the plastic molding for the map lights in order to run the plugs through. Did you have to do this?
VB4Runner
Mitesh
VA
2025 TRD ORP
Thanks, and no, you don’t need to drill if you remove the OEM LED bulbs. There’s a large opening behind them and you can run the connectors for the Meso lights in those openings.
renz244
2025 2026 4runner 6th gen Installed: Meso Customs Map Dome Lights, red rear recovery hook, LAMTTO 360-deg 4-channel dash cam, Racksbrax HD quick release awning mounts IMG_4482
Did you have an issue with this connector? It doesn’t seat all the way into the OEM overhead unit. I know I bought the right lights (I tripped checked) but this connector won’t seat properly. It doesn’t even click. I plugged the original OEM connector to see if it works and it fits properly. I compared the meso connector to the oem and they look identical. I emailed meso customs but Jsut wondering if I’m doing something wrong. I didn’t want to brute force it and possible break something.
6GenChad
Tommy
San Diego
From my knowledge, I know it goes in one way, I'd maybe try and seat it differently and really push it in. I had to give my connector a good amount of force to get it in there
VB4Runner
Mitesh
VA
2025 TRD ORP
I remember it being firm, but not so firm that I felt uncomfortable applying the pressure to seat it properly.
navillus
Bellingham Wa
6th gen orp
Do your maplights (not the rear dome) take like .5 a second to come on? Mine have a slight delay...seems odd.
6GenChad
Tommy
San Diego
Yes, it’s stated on the website that there will be a slight delay for the lights turning on, also that it loses the function of is gradually turning on and off.
navillus
Bellingham Wa
6th gen orp
Guess I need to learn how to read hah, glad it's normal.
Mad Ghost
Justin
Wylie Texas
4Runner ORP and Avalon
The rear? Unless I get a swing out bumper, then yes. Not sure what you’re talking about
Best I can tell your camera that mounts by the license plate is covered by your setup when reversing same with the rear view mirror camera if you have it. So i was curious if you came up with a solution for that.
6GenChad
Tommy
San Diego
Oh my bad, I keep thinking this is my thread haha!! Sorry! I’d assume they did
