JGR
Gabe
Hi everyone!
Been inspired by a lot on here and plan on adding pics along the journey of being a first time 4Runner owner.
Fresh from the dealership
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8288
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8299
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8314
Learned real quick that tint was needed. Went over to TX Tint & PPF in Austin, highly recommend them. Got XPEL XR+, 50 windshield, 15 on sides and 50 all around for uniform look (on top of factory shade).
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8453
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8475
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8472
And the itch hasn’t stopped… so I swapped the Yokohama X-CV’s and got some tires.
BF Goodrich KO3 265/70/17 on the stock SR5 wheels. Swapped the lug nuts to black.
Ended up with C-Rating, I tried the E-Rated for a week and it was too sluggish off the line. After one day of heavy rain, traction control went off causing the rears to swerve, which prompted me to swap.
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8481
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8485
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8489
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8486
Right now, I do have the air dam still on β€” but plan on deleting in future.
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8508
Wasn’t sure how I was going to like the white lettering on all black setup, but i’m digging the contrast at the moment.
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8522
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8519
Looking forward to driving this! Yeehaw!
Updated with new photos:
jc289
Jonathan
boston
2025 4 runner
I just got the 2025 underground sr5 last week . I love it so far still trying to figure out everything about the car
TRD Pro or Die Trying
Anthony
Central Florida
Hi everyone!
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension {filename}
BF Goodrich KO3 265/70R17 on the stock rims. Swapped the lug nuts to black.
That looks awesome! Tint makes a big difference, especially on a black car. Congrats on your sweet ride!
JGR
JGR
Gabe
Appreciate that y’all! Your setups inspire me as well!
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension DSCF2912
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension DSCF2940
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension DSCF2967
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension DSCF2994
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension DSCF2992
Went on a quick trail drive nearby with the wifey for a nice sunset vibes check.
That air dam tho. Lol
JGR
JGR
Gabe
Did some things this weekend…
Swapped out the OEM meep meep and got the Land Cruiser Prado horns installed. Comparison with upgrade and original.
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8762
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8763
Also added a Zekzoop Insulation to the hood. Aside from thermal benefits, I noticed it improved the hood floppiness at highway speeds. Feels more stable with it on, less visual wobble.
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8768
After installing the insulation pad:
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8774
and finally got the air dam off! :)
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8782
Anthony
Central Florida
Is the horn swap a true 'plug and play' or is it more complicated?
JGR
JGR
Gabe
Easy swap! Plug and play, carefully pop off the front top cover, unbolt the original horn and unlatch the cable. Reverse the order for install.
Be careful when transitioning with the cable, if you let it go β€” it can go fall to hard to reach spots.
Anthony
Central Florida
Thanks. That's a mod that I'm going to eventually get to.
  • Like
Reactions: JGR
JGR
JGR
Gabe
Swapped out the Tokico suspension, springs & struts for both front + rears today. Found a TRD OR set off ebay with 60 miles on them.
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8928
It’s actually a huge difference in handling and overall driving experience. Way less rollover and more responsive.
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8980
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_8976
BostonSR5
Nice updates! I’d like to update my sr5’s suspension eventually, too, but money is tight.
I remember reading here cv axles on sr5 were less robust than on other trims. Have you considered that as a future upgrade?
JGR
JGR
Gabe
Had not thought about it until you mentioned it! Definitely a future upgrade, and I haven't found any options available right now. Please share if there are any or OEM alternatives.
The next thing I'm looking at for suspension are possibly Peak Suspension Summit Kit, or a subtle lift on the front.
From what I understand the SR5 and TRD Trims share similar CV axle part numbers and geometry (aside from a few torque specs). Apparently, there is a larger difference on the angles for Trailhunter as they run Old Man Emu setup and are designed for more articulation.
My current setup has no lift and I'm running 265/70R17's. As far as I understand there would be more concern if I was running larger than 285's with a lift higher than 2.5 inches, and gunning it on the trails.
Open to suggestions, or things I should look out for -- it's awesome learning from you all.
Soloflight
Edward
SURREY, BC
Rav4
Hi everyone!
I love it! But what is the difference in mileage in switching to bigger tires?
JGR
JGR
Gabe
With the sample size of about 1,000 miles, I've been getting 17-21 MPG -- honestly not sure if i'm fully 'broken in' yet and it has been tough to resist my heavy foot. lol
Full throttle on this truck is way too fun.
JGR
JGR
Gabe
Lighting upgrades!
Swapped out the cheap bulbs with Lasfit Switchbacks. Significantly brighter and liking the white DRL. Much more reassuring on my night drives, and they do look brighter than ever.
Then the Meso Customs lights arrived, so I had to install them. Here is the interior with stock lights on.
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_1087
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_1098
Original map lights, removing this section felt like I was going to lose my fingernails. Be very careful here y’all!
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_1105
Drilled the holes out for the cables to passthrough.
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_1109
Upper section all reassembled with the new lights. These things are insanely bright, and I’m enjoying the dual modes.
Red lights are much better to use at night while driving and its great to prevent bugs being attracted to the interior.
Waiting on the Meso Rear Dome lights to ship when they’re available. That way when i open the doors and park, it’ll be uniform.
Here’s the interior now:
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_1120
2025 2026 4runner 6th gen 😎 SR5 OEM+ Build on BFG KO3 265/70/17 tires + white lettering (on stock wheels) + TRD OR Off-Road suspension IMG_1115
Highly recommend these upgrades / mods.
