400W Inverter is limited to 100W while driving
san jose can
Looks like the power limitation remains unchanged from the 5th gen.
1) Is there a similar workaround to the 5th gen by means of a wire harness?
2) Any YouTube videos for the 6th gen on this topic? I couldn’t find any. On the 6th gen even if there is a harness available, it looks like the entire rear panel needs to be removed to access the inverter.
3) With a harness workaround is there a safety concern, documented somewhere, with charging around 300W while driving?
As an FYI see 4 scope pictures below.
1st pic: Outlet floating
2nd pic: EcoFlow Delta 2 max, no load
3rd pic: EcoFlow Delta 2 max, 200W
4th pic: EcoFlow Delta 2 max, 300W
Bad news for EcoFlow, the lowest max charge 200W. So while driving it won’t charge from AC since the outlet is limited to 100W. The only option is to charge from 12V which sucks, since it’s limited to 100W, and no 12V socket in the back.
One can potentially conclude that Toyota engineers don’t go camping
2025 2026 4runner 6th gen 400W Inverter is limited to 100W while driving Image 9-8-26 at 10.02 AM
2025 2026 4runner 6th gen 400W Inverter is limited to 100W while driving Image 9-8-26 at 10.04 AM
2025 2026 4runner 6th gen 400W Inverter is limited to 100W while driving Image 9-8-26 at 10.06 AM
2025 2026 4runner 6th gen 400W Inverter is limited to 100W while driving Image 9-8-26 at 10.08 AM
TRD_Alex
New York
Interesting find. I wonder what the situation is with Hybrid outlets.
horbit
DFW
I gave what you asked for at the bottom. I googled it for you.
buy a new alternator now while they are cheaper than they'll be in a year
  • Alternator Load Management: While driving, your vehicle is already powering critical components like headlights, climate control, electric power steering, and active safety sensors. The 100W limit prevents the inverter from aggressively competing for alternator priority.
  • Thermal Limitations: The factory inverter is relatively small and housed in an area without active ventilation. It is designed for intermittent use rather than continuous, heavy duty cycles.
Thermal Heat Buildup
    • Running a constant 400W load for multiple hours on a road trip will cause the inverter to get quite hot.
    • The inverter features built-in thermal protection. If it gets too hot, it will automatically shut off or drop the light on the switch rather than melting the wires
Battery & Alternator Strain
    • A 400W load translated through a 12V DC system draws roughly 33 to 40 Amps.
    • If you are running the inverter at max capacity while idling at a red light with the A/C blasting, your alternator might struggle to keep up, momentarily drawing power directly from your 12V starter battery
Modified Sine Wave Issues
    • The factory inverter outputs a modified sine wave, not a pure sine wave.
    • Sensitive electronics or portable power stations may run inefficiently, buzz, or generate excess internal heat when plugged into a modified sine wave. This issue occurs regardless of whether you bypass the driving restriction.
Blackie1
Paul
2026 4Runner
So I'm an idiot but if I install the CaliRaised kit can my wife sit in the passenger seat and work on her laptop while I'm driving? And is the 400 anytime kit all that I'd need to install or is there other stuff that's needed.
horbit
DFW
I don't think you would need over 100w for a laptop unless it was a gaming one, you can check the wattage of the laptop power brick to be sure. If you planned on having more things plugged in while driving then yes the anytime kit would be beneficial.
Blackie1
Paul
2026 4Runner
On a vacation this Summer the laptop draws over 100w so that's why I'm interested. She's an architect and that software takes a load to run properly.
horbit
DFW
Yea sounds like a harness would be a good option then to ensure the laptop charging can keep up with the demand.
I can't speak for long term safety of overriding Toyotas engineering, but up to 400watts isn't much power load to add on 24/7 and the circuit is already designed to support it in park.
san jose can
Anyone had any luck with the “400 Anytime Kit” on the 6th gen? Looks like they’re out of stock for now. I’m leaning towards swapping the inverter. I’m looking at the Victron true sine wave 375VA. I used that model on my previous truck. The only concern is the size, they’re fairly bulky (10.25” x 6.5” x 3.4”).
san jose can
The inverter is located under the center console. Dimensions are 5” x 5.5” x 2”. There isn’t much more room to fit a larger inverter. There is some empty space there, but the shifter cable is in the way.
Under the passenger seat there is hardly any room.
The simplest option is use the 400 Anytime kit, and live with the modified sine wave. You would have to remove the center console to install it. There is a YouTube video showing the process.
The alternative is to run new set of wires to the cargo area and mount the inverter externally. I probably won’t be going this direction.
See pictures for your reference.
2025 2026 4runner 6th gen 400W Inverter is limited to 100W while driving IMG_3547
2025 2026 4runner 6th gen 400W Inverter is limited to 100W while driving IMG_3548
2025 2026 4runner 6th gen 400W Inverter is limited to 100W while driving IMG_3546
2025 2026 4runner 6th gen 400W Inverter is limited to 100W while driving IMG_3549
