Coldwiz
Frank
Saukville Wisconsin
Avoid using accessory mode is the short story but there's info on how to test if the DC to DC converter is charging the 12v battery. Wonder how the alternator on trucks equipped with one plays into this?
Summary by AI
How Toyota Hybrids Work Without an Alternator or Starter
  • No Starter Motor or Alternator: Unlike traditional gas cars, Toyota hybrids (such as the Prius, Camry, RAV4, and Corolla) do not have a belt-driven alternator or a traditional 12V starter motor [01:57]. Inside the transmission are two motor-generators: MG2, which primarily drives the wheels, and MG1, which uses high-voltage power to spin up the gas engine (acting as the starter) and generates electricity to recharge the main hybrid battery [03:20].
  • The 12V Battery as a "Pilot Light": Because MG1 handles starting the engine, the small 12V battery does not need the heavy cranking amps required in a gas vehicle [03:55]. Instead, it acts like the pilot light on a furnace—when you press the power button, the 12V battery wakes up the vehicle's computers, runs system checks, and closes the heavy-duty relays that connect the high-voltage hybrid battery [04:20]. If the 12V battery is weak, the car cannot enter READY mode, even if the expensive hybrid battery is completely healthy [04:56].
  • The DC-to-DC Converter: Tucked inside the under-hood inverter/converter assembly is a DC-to-DC converter [05:28]. It takes lethal high-voltage electricity from the main hybrid battery and steps it down to roughly 14 volts to power all 12V accessories and recharge the 12V battery [05:53].
The #1 Reason 12V Batteries Die Prematurely
  • The "READY Mode" Rule: The DC-to-DC converter only operates when the green READY light is illuminated on the dashboard [06:49].
  • Accessory Mode Drain: If you press the power button without pressing the brake pedal, the car enters Accessory or ON mode [07:13]. In these modes, the high-voltage relays remain disconnected and the converter stays asleep—meaning the radio, screens, fans, and chargers pull power directly from the small 12V battery with nothing replenishing it [07:26]. Sitting in the car in Accessory mode (such as waiting in a school pickup line or finishing a podcast in the driveway) combined with short trips and cold weather quickly drains the small battery [07:52].
Symptoms, Diagnostics & Replacement Traps
  • Signs of a Weak 12V Battery: A failing 12V battery typically causes the car to partially wake up without entering READY mode, accompanied by dim or flickering screens, erratic door locks, and a cascade of scary dashboard alerts (brake, stability control, and hybrid system warnings) triggered by low voltage across the computers [10:50].
  • How to Test with a Multimeter: Using the under-hood jump terminal (usually under a red cover in the fuse box), check the voltage with a basic multimeter [11:32]:
    • Car Fully Off: A healthy battery reads around 12.6V; 12.0V or lower indicates a deeply discharged battery [11:46].
    • Car in READY Mode: Voltage should jump to 13.8V–14.4V, confirming the DC-to-DC converter is charging properly [12:08]. If it stays at 12.5V or lower in READY mode, the converter itself has a fault—often linked to a neglected or failing inverter coolant loop [12:32].
  • Battery Replacement Warning: In many Toyota hybrids, the 12V battery is mounted inside the cabin or cargo area rather than under the hood [09:58]. In these locations, you must replace it with a proper sealed AGM battery with a vent tube rather than a cheap standard flooded battery, which can vent hazardous gases into the passenger compartment [10:12].
Jump-Starting & Prevention Tips
  • Safe Jump-Starting: Because the 12V battery only needs to power up the computers, a small portable jump pack is sufficient [13:27]. Always double-check polarity—reversing the cables on a hybrid can destroy the expensive inverter assembly [13:51]. Once jumped, leave the car in READY mode for at least 30 minutes or take a long drive so the converter can recharge the battery [14:12].
  • Preventative Habits:
    • Always put the car in READY mode (foot on the brake) when sitting parked with accessories running, ensuring you are never in an enclosed garage or leaving the vehicle unattended [14:39].
    • Give the vehicle a longer drive or a 30-minute READY session once a week if you mostly take short trips [15:01].
    • Watch for parasitic drains from hardwired dash cams in parking mode, aftermarket trackers, or storing your smart key fob right next to the garage wall where the car constantly communicates with it [15:16].
    • Have the 12V battery tested routinely once it reaches 4 to 5 years old, especially ahead of winter [15:43].
spyder40
Indiana
2021 4Runner ORP
Wonder how we can start a hybrid if the hybrid battery gets low given the 12v only runs electronics
talmadge
Timothy
SLC, UT
That’s incorrect, the HEV 4Runner does indeed have a 12V starter. Check page 28: https://www.toyota.com/content/dam/toyota/brochures/pdf/2026/2026_4runner_brochure.pdf
I believe it uses the 12V starter motor on the first crank and then during operation relies on the motor generator to restart the engine during normal auto start/stop. The 4Runner hybrid is quite a bit different from the THS II design present in the other Toyota hybrids.
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
Pretty sure the hybrid battery mainly recharges off of braking. Uses some alternator as well. Unlikely hybrid battery dies.
This article was interesting given some starter battery issues I had on a recent camping trip. Note when Toyota replaced the battery under warranty they gave me a crappier starter battery ( substandard to what seems to be required) because that’s what is covered by warranty.
if you want a good video on the BoF ev system vs toyota's traditional ev system view these 2 videos
i havent found anyone that comes close to these 2 videos
josiahg52
Josiah
Maine, United States
I've yet to see anything except 0 when monitoring Alternator Current and Alternator %. As an alternator is not included on all hybrids, the alternator does not contribute to HV battery charging. It is maintained and charged via regenerative means and the engine driven motor-generator. Since an alternator is included with the AUX switches option, I think the alternator provides 12V charging overhead in the event it's needed because of combined AUX loads exceeding the DC to DC converter capacity or the 12V battery drops below some critical level of charge state or voltage.
