- First Name
- Marie
- Joined
- May 22, 2026
- Threads
- 5
- Messages
- 24
- Reaction score
- 33
- Location
- Seattle, WA
- Vehicle(s)
- 4Runner
- Thread starter
- #1
We recently launched a new winch, the ARB Winch, and we wanted to lay it out here for anyone speccing a 6th gen (2025+) 4Runner. It's a ground-up redesign rather than a refresh of an older platform, built around how modern 4x4s are actually loaded and used today. Below are the key specs and the areas where it's built differently from most of the winches already out there.
About The Winch
The ARB Winch is a compact, fully integrated recovery winch available in 10,000-lb and 12,000-lb ratings. It was built to handle the demands of modern, heavily equipped rigs, with consistent power, smart heat management, and a simpler installation process.
Top Features
- 10K and 12K capacity
- Electronics integrated directly into the winch housing, so there's no bulky external control box to find room for
- 4-stage hardened steel gearbox for smooth, controlled pulling power under heavy load
- Gearbox-mounted brake for 100% load holding and powered unspooling without cooking the winch
- Synthetic rope standard, since it's safer and easier to handle than steel cable
- Dual connection remote: 2.4 GHz wireless up to 130 ft, plus a hardwired option up to 16 ft
- IP68 rated for water and dust
- Pre-wired connections for a clean, hassle-free install
Most winches on the market haven't changed much in years. They get the job done, but a few familiar pain points show up when things get serious. Here's how we tackled them.
Heat
On a lot of winches, the brake sits inside the drum, which dumps heat straight into your rope and degrades the line over time. We moved the brake into the gearbox, away from the drum entirely. Less heat on the rope means better durability and more consistent performance, pull after pull.
Electrical Complexity
A separate control box means more wiring, more connections, and more places to fail in wet, muddy, or dusty conditions. We replaced it with a custom Albright contactor built directly into the winch, sealing everything into one compact, IP68-rated unit. Fewer connections mean fewer things to go wrong when you're already in a stressful spot, and the pre-wired connections keep installation straightforward.
Performance Drop-Off
Plenty of winches start strong and then slow down as they heat up under load. Our 4-stage hardened steel gearbox and tuned 12V motor work together to hold consistent pulling power and line speed through extended recoveries.
Low-Profile Design
Many winch designs on the market are bigger and bulkier than they need to be, which makes them a tight fit on bumpers. Our winch is noticeably more compact, so it fits and works with most bumpers on the market, and gives the front end a much cleaner look.
10K vs 12K: Which One for a 4Runner?
For most 6th gen 4Runner builds, the 10K is plenty (the rule of thumb is roughly 1.5x your loaded vehicle weight). If you're running a heavier overland setup (steel bumpers front and rear, drawers, RTT, full water and fuel) and want extra headroom for mud and steep, loaded pulls, the 12K is the safer bet.
Both ratings share the same core hardware. Each runs a gearbox-mounted, 100% load-holding proportional friction brake, a 171:1 gearbox (2-stage planetary plus 2-stage spur), and an Albright 500 amp DC contactor, with an IP68-rated motor and gearbox. Both also ship with a main power isolation switch and a remote-mounted control plug.
Full specs side by side:
| ARB 10K Winch | ARB 12K Winch | |
| Rated Line Pull | 10,000 lb / 4,536 kg | 12,000 lb / 5,443 kg |
| Rope | 10 mm x 92 ft Grey Synthetic | 11 mm x 79 ft Grey Synthetic |
| Fairlead | Forged 6061 Aluminum Hawse Fairlead | Forged 6061 Aluminum Hawse Fairlead |
| Fitted weight | 73.5 lb / 33.3 kg | 76 lb / 34.5 kg |
| Max Line Speed | 60 ft/min | 65 ft/min |
| Motor | 5.3 HP | 5.7 HP |
| Warranty | Limited lifetime + 7-year electrical | Limited lifetime + 7-year electrical |
Mounting the Winch on a 6th Gen 4Runner
If you're wondering how this mounts up on a 6th gen 4Runner, there are a couple of things worth knowing.
Because the control box is built into the winch housing, there's no separate box to hide behind the fascia or zip-tie inside the engine bay, which is one of the bigger packaging headaches on the new 4Runner with all its sensors and camera hardware up front. The winch itself mounts to a standard low-mount winch cradle, so it'll drop into any winch-ready bumper built for the 6th gen 4Runner that uses a conventional mount pattern, including the concealed/center-mount designs that keep factory parking sensors, the front camera, and Toyota Safety Sense intact.
And for those of you waiting on an ARB front bumper for the 6th gen 4Runner, it's in the works. We're not putting a date on it yet, but it's coming. If you're planning a build around this winch now, it'll work with current winch-ready 6th gen bumpers in the meantime, and we'll post here the moment our bumper is ready so you can see how the full front end comes together.
Have Questions?
We know a winch is a real purchase and there's a lot to weigh: which capacity is right for your build, how it installs on the 6th gen platform, and whether it's worth it over the usual names. Drop your questions below, and we'll answer them.
Want to see what we have available for the 2025+ Toyota 4Runner? Check out our available products!
