“OMG Stop Beeping at me!!”. How do I mute or muffle the door and hatch beeps?
I meant a dealer accessible list. I understand how they would do it.
that is too much to list. what you see above is just 1 sub system. the amount of screens in GST is huge even when it wasnt GST and they had a stand alone version you could install on a laptop yourself.
there is soo much in GST outside of things you as a customer want to change, it also has all the screen for engine, ecu, safety, etc. you have to know what major/sub/sub screen for all the things you can modify in a vehicle and thats just one model.
toyota moved to GST (global techstream) from TS (techstream to weed out the hackers installing it for personal use, i had an old version zip file that went up to 2018 vehicles but since the 2020's toyota moved to a web based version that needs a constant connection to work)
here is a post from the 3rd gen tundra forums, as you can see, the list all the things you could change on a single vehicle is just too much info to actually have the time to post.
and if you could, toyota lawyers would have a say in that. that how poeple get banned from forums. any posting of techstream screens is proprietary info and toyota goes after people for that. (its actually a requirement you accept when you log into GTS, even if you do a 2 day paid pass)
i know of good guy that posted that type of info and promptly got banned by the forums by the toyota lawyers (aka ryan)
EDIT : i forgot to add, this list below is maybe 5-10 % of the all the things that could be changed on a vehicle thru GTS (global techstream)
and a lot of stuff is changed just to do service on a vehicle not to just customize a function.
like retracting the automatic parking brake
1. CUSTOMIZE POWER TILT AND POWER TELESCOPIC STEERING COLUMN SYSTEM
2. CUSTOMIZE ACTIVE NOISE CONTROL SYSTEM
3. CUSTOMIZE INTUITIVE PARKING ASSIST SYSTEM
4. CUSTOMIZE PARKING SUPPORT BRAKE SYSTEM
5. CUSTOMIZE BLIND SPOT MONITOR SYSTEM
6. CUSTOMIZE SAFETY CONNECT SYSTEM
7. CUSTOMIZE POWER DOOR LOCK CONTROL SYSTEM
8. CUSTOMIZE WIRELESS DOOR LOCK CONTROL SYSTEM
9. CUSTOMIZE SMART KEY SYSTEM (for Entry Function, HEV Model)
10. CUSTOMIZE SMART KEY SYSTEM (for Entry Function, Gasoline Model)
11. CUSTOMIZE SMART KEY SYSTEM (for Start Function, HEV Model)
12. CUSTOMIZE SMART KEY SYSTEM (for Start Function, Gasoline Model)
13. CUSTOMIZE THEFT DETERRENT SYSTEM
14. CUSTOMIZE MY SETTINGS SYSTEM
15. CUSTOMIZE LIGHTING SYSTEM(INT)
16. CUSTOMIZE METER / GAUGE SYSTEM.
17. CUSTOMIZE HEADUP DISPLAY SYSTEM
18. CUSTOMIZE FRONT POWER SEAT CONTROL SYSTEM (w/ Memory)
19. CUSTOMIZE SEAT HEATER SYSTEM
20. CUSTOMIZE CLIMATE CONTROL SEAT SYSTEM
21. CUSTOMIZE REAR SEAT REMINDER SYSTEM
22. CUSTOMIZE SEAT BELT WARNING SYSTEM
23. CUSTOMIZE AIR CONDITIONING SYSTEM (for HEV Model)
24. CUSTOMIZE AIR CONDITIONING SYSTEM (for Gasoline Model)
25. CUSTOMIZE POWER WINDOW CONTROL SYSTEM
26. CUSTOMIZE SLIDING ROOF SYSTEM
27. CUSTOMIZE PANORAMIC MOON ROOF SYSTEM
28. CUSTOMIZE POWER MIRROR CONTROL SYSTEM (w/ Memory)
29. CUSTOMIZE POWER MIRROR CONTROL SYSTEM (w/o Memory)
30. CUSTOMIZE WIPER AND WASHER SYSTEM
31. CUSTOMIZE LIGHTING SYSTEM (EXT) (w/ Headlight ECU)
32. CUSTOMIZE LIGHTING SYSTEM (EXT) (w/o Headlight ECU)
33. CUSTOMIZE PRE-COLLISION SYSTEM
34. CUSTOMIZE DYNAMIC RADAR CRUISE CONTROL SYSTEM (for HEV Model)
35. CUSTOMIZE DYNAMIC RADAR CRUISE CONTROL SYSTEM (for Gasoline Model)
36. CUSTOMIZE LANE TRACING ASSIST SYSTEM
37. CUSTOMIZE ROAD SIGN ASSIST SYSTEM
38. CUSTOMIZE AUTOMATIC HIGH BEAM SYSTEM
axxman
Axel
Columbia MD
2026 4Runner Off Road Premium (fall 2026)
I would respectfully disagree, my neighbors have Toyota's (and other mfg) that been and I get woken up constantly, that being said, I have turned mine down as low as possible and I can live with that, the only remaining annoyance I have is the seatbelt alarm.
