4Runner keeps beeping - what does it mean? Truck turned off, doors open.
the logic on the rear seat reminder is crappy at best. if you open a rear door and dont do a corresponding door opening, it will beep.
they really should have put a pressure sensor on the seat pad than using the door open/close sequence.
sometimes i put something in via the door and take it out with me when i exit the drivers seat, or vice versa, take it with me (hoodie) and take it off and take it out via the back seat.
rear seat weight sensors will not work properly for a variety of reasons.
Toyota has already solved this rear seat reminder problem**,
but it is currently only on the Sienna. ARSR mmWave sensing...
and it might be added to more models in 2026 and onward.
(if something moves in certain scanned locations in
the rear even a tiny bit, you'll get an alert)
https://support.toyota.com/s/article/Advanced-Rear-Seat-Reminder?language=en_US
**It may never fully stop false alarms, but it will increase positive alarms which
is the main goal. "So we annoyed you, so what ?" But if we don't alert you while
some kid is left in back dying, that is what we are trying to remedy.
good thing i have mine folded flat since it just me 95% of the time, ignores the whole issue :)
Not made in China
Bicycle
Does there Toyota app show a notification with any sort of hint what might be causing it. If the dash cam, that is a good find for those with that option.
Dinosoar21
Northern Virginia
2025 Toyota 4Runner SR5
Yeah, it's annoying, but I don't believe it is sensor driven, just a user-selected warning. That said, you can turn it off in the dash settings (not the app). Gotta dig a little, but you'll find it...then select "OFF"
it's about opening and closing doors sequence. if you open rear door only
once in any drive cycle, it's gonna bark at you if you don't open a rear
door again when you park and shut it off and leave. I've disabled it in the MID.
BadgerBoy
Waldport, OR
2025 Toyota 4Runner TRDOR
This happened several times the last week or so, and I've never heard it until now. It happens when the truck is off. I thought maybe it was just telling me that I had the key in the truck but not sure...
BadgerBoy
Waldport, OR
BadgerBoy
Waldport, OR
I have a similar problem with my 2025 TRD Off-road premium. I use the door lock switch when I exit the driver's door. OFTEN after driver's door shuts, it will beep NINE times from inside the cab! No key left inside, all windows rolled up, etc. Other times, using door switch or remote key fob, it's one beep and done. Maddening and irritating as heck
BadgerBoy
Waldport, OR
you dont have a moon roof do you?
have you tried turning off rear seat reminder? (this one is a major pita since the logic on it is wonky from my pov)
those are the only other things beside key warning beeps and window open beeps.
BadgerBoy
Waldport, OR
Yes, I have a moon roof, and the back seat check reminder comes on when it shouldn't! I'll check both. Thanks.
