alldogsoffroad
Chad
Lincoln, NE
2025 Toyota 4Runner SR5
Hello friends,
As more people look to DIY their suspension installs they're going to be seeking torque specs / values / figures for the front and rear suspension. Here is a list that we've compiled so far from various sources. We will continue to add to the chart as needed. If anything looks out of place let us know and we will make corrections!
ComponentFt/LB
Front Upper Tophat Nut33
Front Shock Upper Stem Nut48
Front Shock Lower Bolt195
Front UCA Ball Joint Nut92
Front UCA Mounting Bolt145
Front LCA Ball Joint Nut117
Front LCA Ball Joint Bracket to LCA Bolts221
Front LCA Cam Bolt103
Front Swaybar to End Link159
Rear Shock Upper Stem Nut39
Rear Shock Lower Bolt77
Rear Swaybar to End Link55
Rear Trackbar115
Rear Lower Control Arms103
Last updated - 12/16/25
Seattle
'25 4Runner
Doh, I just came across this *after* getting all the torque figures from the service/repair manuals (techinfo.toyota.com). This is rad, thanks for putting it together!
FWIW, numbers check out with RM figures for factory. TC UCA instructions (https://www.chaosfab.com/PDF/96524.pdf) note slightly different figures for thru-bolt (136ft/lbs) and ball joint nut (90ft/lbs), but close enough I suppose.
0801
Seattle
'25 4Runner
May also be useful:
Tie rod (to steering knuckle, not lock nut): 89 ft/lb (then turn to align cotter pin)
Rear upper control arm: 103 ft/lb
Rear lateral control arm: 115 ft/lb
wheel/lugs: 97 ft/lb
