Why go with 17" wheels over factory 18" wheels?
Striker53
Sean Ruth
Prince George
2025 off road Premium
Just wondering why everyone seems to go to 17" rims rather than the 18" that come with it?
Backcountry1
Kelowna
mazda6
From my limited knowledge I would say 17’s are better for off road as you can get more sidewall. Example a 34” tire on a 17” rim has more sidewall than on an 18” rim. Also, it seems easier to find C rated all terrain tires which offer better ride. Like I said this is just my take on what 17’s offer over 18’s.
Mad Ghost
Justin
Wylie Texas
4Runner ORP and Avalon
Tire availability. Not sure about other brands but the 5th gen ran 17’s and there are 15 years and 100 of thousands of them on the road for each year. So lots of customers. First year on a new size and so far only a few thousand sold. I’m sure over time we will see more options for the 18
HedgeHog
Rob
Georgetown, Ontario
Toyota 4Runner
My 4Runner came with 20”, winters are in 18”, to compensate, the aspect ratio is adjusted so you get the same rolling circumference for accurate miles/hour. As previously mentioned, you get a softer ride because the sidewall/bead size increase but also… its generally cheaper for the cost of the tires as well.
odins_beer'd
Right on the money, that’s why I find it so funny the off-road higher trims have bigger wheels. Then again the vast majority of people buying them will never use them heavily off-road if at all. Which is okay too.
Joe Dirt
That's my take exactly,
my fifth gen came at 17.
I went with Nitto Tires and Method Wheels only to find that the wider wheel squatted the tire down about an inch so i actually lost ground clearance by going with methods and Nitto Tires of the same Factory size.
Now fast forward to my 6th generation 4Runner it came with 18 inch wheels with 265 70s,
I will go 275 70 18 and a bilstein 6110 leveling kit all the way around and leave it at that.
Just my two cents.
