Cory39744
Cory
Virginia, USA
How are you taking your measurements? Those numbers don't add up from fender to center hub.
papadop88
papadop88
Los Angeles
2025 4Runner TRD Pro
Sorry, I have that info in the description of my YT video but forgot to put it in the thread. I’ll add that.
I usually do bottom of fender to center hub, but for this application I do bottom of rim to bottom of fender. I do that because the sidewall of the tire pokes out so much I can’t get a steady reading using gee center hub as it distorts the measuring tape. By clipping it to the bottom of the wheel, I can get a better reading.
It’s the same effect except that the measurements this way will be 9” higher than doing it from the center hub. So if you’ve been measuring from the center hub, then subtract 9” from my measurements. (18” wheel divided by 2)
Cory39744
Cory
Virginia, USA
awesome! That’s what I was thinking but wanted to be sure. I am kinda in the same boat as you with my Pro. I took a slightly different route though. I have Dobinsons rear springs which net just over .5in higher than your setup in the rear and I have a 1in Peak Suspension top spacer on the front which nets about 1in less than yours. This result is about a 2in front rake. I’ve been waiting for Eibach to release their TRD Pro springs but the WD collar only seems like it would set me up perfectly.
Cornfed Suspension also makes a 1/4 thick top spacer that results in 1/2in of lift which would correct the driver side front lean. I’m planning on doing that as well.
papadop88
papadop88
Los Angeles
Gotcha. Ya since you already have the Peak puck up front see if they will sell you their preload collars specific for the Pro only (they have less preload). That should give you 1.2” of lift in the front and give you that perfect rake. But not sure how that changes with your Peak spacer up top…
Dobinsons springs are so damn tall.
If needed or wanted, I have my top hats I didn’t install for sale so just let me know. Swap the Peak pick out for the top hats and add a preload collar…but I also believe Peak makes a collar, just not sure of the lift it gives you.
Cory39744
Cory
Virginia, USA
Peak isn’t going to make a collar for the Pro. I will take the top spacer off if I get the WD preload collar. Then I would have the same specs in the front as yours and 33in in the rear with the Dobinsons which would be perfect.
Cory39744
Cory
Virginia, USA
The Dobinsons spring lift numbers are based on the lower trims. On my pro, I’m only just under .5in higher than you
papadop88
papadop88
Los Angeles
Here are the videos showing the install of the VViViD Air Tint film I used to wrap my Rigid fog lights to selective yellow, and the follow up video showing the beam at night. I love selective yellow as I've always run that lens on my Baja Designs lights.
Wrap job took about 20-25 mins. Pretty easy install using this film.
My OCD though is creepin into my thoughts about the mismatch of the amber DRLs and Raptor lights and the selective yellow fog lights now...may pull them the off...may not. We'll see.
TRD Pro or Die Trying
Anthony
Central Florida
Thanks for the videos. I love your content. Does the VViViD Air Tint film come in an amber color?
papadop88
papadop88
Los Angeles
Very welcome. VViViD does not, but Lamin-X does and I'm sure a couple other Chinese brands on Amazon might.
If you want Amber, use Lamin-X as they are legit and amazing quality. I'm just not a fan of amber fog lights otherwise I would have gone with amber.
Anthony
Central Florida
Thank you. I actually decided to order the amber from Lamin-X. Pretty inexpensive and easy to undo if I don't like it. I kind of like the idea of the fog lights matching the DRL's. I'll let everyone know how it turns out.
Formidable
Bellevue, WA
2025 TRD Pro
...and here's the video explaining everything and why I did what I did by not installing the top hats. Math is math.
Thanks for posting the review of the WD lift and the details. Do you have any side shots of the truck demonstrating how the front vs rear sits? Agree that reverse rake is no bueno.
papadop88
papadop88
Los Angeles
Sure thing. Here's a side shot of how she sits currently.
As you can see, it's almost exactly level, with an approximate .5" front rake, which is absolutely perfect. At least for my truck. That's why I'm saying...adding the 1" top hat which gives you an additional .5-.7" lift in the front would give me an absolute reverse rake.
2025 4runner 6th gen Papadop88's Underground 2025 4Runner TRD Pro 6th Gen Build IMG_0858 Larg
BillyG4Runner6G
Billy
Delaware
Can nyone out there give me their best estimate on the lead tim for the Westscott Design kit like John has installed after placing an order? They don't list just the bottom pre-colllar lift and rear pucks on their site as a kit and I have not heard back if they will just send me what I need.
papadop88
papadop88
Los Angeles
DM'd you.
