bossman
SF Bay Area
2026 Toyota 4Runner, 2020 Audi S6, 2023 Rivian R1S
Well I can confirm that you are stuck with it if you have a post 7/26 build date. I bought carista and a scan tool and neither of them can access the seatbelt reminders.
which scan tool? Was it the LAUNCH Creader?
the scan tool doesnt really affect the software. its the software and how it interacts with the ecu and pids codes. or they moved them to new pid codes and no one hasnt found them yet.
i am guessing toyota did something totally radical with the pid codes and how they are hidden without GTS (global techstream)
axxman
Axel
Columbia MD
this is depressing, the seatbelt chime is the last annoying beep I need to address on mine, gonna double check the mfg date, but I think since I just picked it up fresh off the truck 2 weeks ago, I am probably post July. I really dont want to start using one of those seatbelt adaptor things.
update the mfg plate says 7/2026
Patience, I'm sure they will add it in a future update. To hasten the update, contact their tech support.
[email protected]
yeah i tried that, waste of time. all you get is an AI bot walking you thru steps to get debug files.
tried for 2 weeks and the app takes longer than 20 mins to pull a report (the vehicle shuts off after 20 mins of power drain) so i gave up trying and just let the sub lapse.
during that whole time, its just the AI bot sending emails to try the same process differently.
first time i send the debug report and it told me to try a different way to get the debug report.
it should not take longer than 20 mins to pull a debug report.
ROBERT18452
ROBERT18452
Robert
Scranton, Pennsyltuckey
25 Gen6 4runner limited
Have you tried it with the engine running?
it tells you to put the vehicle in "ON" mode, not running.
doing the debug it gets to around 38% and the vehicle shuts off, i am not going to sit and run my vehicle for 40-60 mins to get a dam debug report for them.
and i tried the process 3 times and it only gets to around 38% every time.
2025 2026 4runner 6th gen Carista App v10.1.1 gets new features Screenshot_20261027_072528_Gmail
when you dont go thru the debug process the AI bot emails you, and go thru the normal scan process, it takes maybe 2-3 minutes, closer to under a minute usually.
josiahg52
Josiah
Maine, United States
I'm sure you've gone through the menus, the seatbelt warnings were in the Warnings menu, not Seats, and I did all of my scanning and programing engine on, or READY in hybrid speak.
If the PIDs are there, Carista and Launch will get thrm eventually, I'd guess.
Joestac
Just to make sure my '25 still had the option I checked this morning and like others have said it is still there. They also offered me 35% off another year at $38.99, and I had $16 in Google Play credit from reviews, so I pulled the trigger. Good until Jan 2028 now.
"The following settings were available specifically to your vehicle using Carista:
Most Popular:
Lane-change turn signal auto-flasher count
OFF / 3 FLASHES / *4 FLASHES* / 5 FLASHES / 6 FLASHES / 7 FLASHES
Seat belt warning ding (driver)
ENABLED / *DISABLED*
Seat belt warning ding (front passenger)
Daytime running lights
*ON* / OFF
Coming-home lights duration
OFF / *30 SECONDS* / 60 SECONDS / 90 SECONDS
Seat belt warning ding (rear right passenger)
Seat belt warning ding (rear left passenger)
Seat belt warning ding (rear center passenger)
Auto fold side-view mirrors (req. power folding mirrors)
WITH IGNITION / *WITH DOOR LOCKS* / DISABLED
Open windows and sunroof via long-press on remote
*ON* / OFF
Chassis & Engine:
Active Noise Cancellation (ANC)
*ON* / OFF
Engine Sound Enhancement (ESE)
ON / *OFF*
Dings & Warnings:
Warn when doors opened with headlights on
*ON* / OFF
Ding when key is left in the car
*ENABLED* / DISABLED
Driver Assist:
Rear Cross Traffic Alert (RCTA) system
Blind spot monitor
Heater & A/C:
Temperature dial calibration
-2 °C (28.4 °F) / -1 °C (30.2 °F) / *NORMAL* / +1 °C (33.8 °F) / +2 °C (35.6 °F)
Instruments: Displays & Nav:
Instrument lights restoring sensitivity
DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST
Display odometer after ignition is turned off for…
30 SECONDS / *1 MINUTE* / 10 MINUTES / OFF
Microphone sensitivity
Speaker volume
Lights: Automatic:
Auto headlights activation threshold
Turn headlights on when wipers operated continuously and headlights are switched on AUTO (req. auto headlights)
Lights: Exterior:
*ON* / OFF
Turn signal click volume
*LOW* / MEDIUM / HIGH
Turn on marker lights when vehicle is unlocked via remote
Lights: Interior:
Turn on interior lights when you shut off engine
*YES* / NO
Turn on interior lights when smart key in range
*YES* / NO
Interior footlight (bright when doors open, dim when driving)
*YES* / NO
Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
*YES* / NO
Locking: Automatic:
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / *60 SECONDS* / 120 SECONDS
Locking: Beep & Blink:
Blink hazard lights when vehicle is locked via remote
Locking: Doors & Alarm:
Max number of consecutive lock/unlock cycles via touch sensor
UNLIMITED / *2 TIMES*
Warn (beep) when a window is still open when locking doors
*YES* / NO
Warning when door is locked via button on door handle while ignition is left on
*YES* / NO
Locking: Smart Key:
Touch-to-unlock-doors minimum duration
OFF / SHORT / *MEDIUM* / LONG
After locking with smart key, don't allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / *2.5 SECONDS* / 5 SECONDS
Smart key location to start car
FRONT AND BACK SEATS / *ANYWHERE IN VEHICLE*
Mirrors:
Parking Sensors:
Activate parking sensors in neutral (N)
*YES* / NO
Front center parking sensor range
SHORT / *LONG*
Front corner parking sensor range
SHORT / *LONG*
Parking Support Brake (PKSB) vehicles from rear detection
Parking Support Brake (PKSB) rear detection sensitivity
*STANDARD* / LOW
Seats & Steering Wheel:
Seat airflow level
*NORMAL* / SILENT (HIGH) / SILENT (LOW)
Easy entry/exit
*DISABLED* / RETRACT STEERING WHEEL FOR EASY ENTRY/EXIT / TILT AWAY STEERING WHEEL FOR EASY ENTRY/EXIT / RETRACT AND TILT AWAY STEERING WHEEL FOR EASY ENTRY/EXIT
Trunk:
Rear hatch walk away kick sensor
Trunk kick sensor sensitivity
Trunk front seat switch button
SHORT PRESS / *LONG PRESS*
Rear hatch open/close via remote
*ON* / OFF
Rear hatch open/close with "one motion"
*ON* / OFF
Rear hatch remote press
SHORT PRESS / 2 SHORT PRESSES / *LONG PRESS*
Beep while opening/closing power rear hatch
ON / *OFF*
Windows & Sunroof:
*ON* / OFF
Beep when using windows comfort close with ignition off
Open windows and sunroof by turning and holding key in door lock
ON / *OFF*
Close windows and sunroof by turning and holding key in door lock
ON / *OFF*
Passenger window single-touch-open from driver's switch
Window (rear left) single-touch-open from driver's switch
Window (rear left) single-touch-close from driver's switch
Window (rear right) single-touch-open from driver's switch
Window (rear right) single-touch-close from driver's switch
Wiper voice control
Wipers & Washer:
Auto-enable rear wiper when front wipers on and reverse gear engaged
SWITCH REAR WIPER FROM INTERMITTENT TO PERMANENT WIPING WHEN IN REVERSE / *TURN ON ONCE* / DISABLED
Enable rear window wiper when trunk is open
Other:
Panic function on remote
Obtained with Carista 10.1.1 for Android."
Also interesting is Advanced ECU Check revealed some codes even though I have no issues.
Body/convenience system
Calibration ID: 8922F35030D0
Fault codes:
B120687 Crash Occurred: Missing Message
B232187 D-Door P/W System: Missing Message
Rear hatch
Calibration ID: 8922G35010C0
Fault codes:
B225101 Back Door Closer Switch: General Electrical Failure
Transmission
Calibration ID: 8A2103507100
[No fault codes]
Digital rear view mirror
Fault codes:
U014087 Lost Communication With Body Control Module: Missing Message"
the general electrical failure i have not seen before on my 25 or 26
the other 3 show up normally
Joestac
My Android app just got an update to 10.1.2. Version release date of Oct 23rd.
"Android Auto: See live car data on your infotainment screen!
Monitor key OBD2 data like oil temperature, coolant temperature, and battery voltage directly on your display — clear, safe, and easy to check at a glance"
JCinNC
JC
NC
Guys, confirming you do need to have the engine running...I used my Carista yesterday, and the seat belt chime toggle was there, so hopefully you are seeing it on yours as well.
