Guys, confirming you do need to have the engine running...I used my Carista yesterday, and the seat belt chime toggle was there, so hopefully you are seeing it on yours as well.
You joined in June, when was your 4Runner built? The option appears to have disappeared from those '26 built after July.
axxman
Axel
Columbia MD
2026 4Runner Off Road Premium (fall 2026)
Was able to spend some time with this thing, I was able to turn on the power windows roll down option, turned off fake engine noise, I tried turning off ANC but I ended up turning it back on, not sure if it was my imagination or not but the car seemed less quiet. Also again, not sure if it was my imagination or not, but but the stereo seemed to sound better with both off. No sign of the seatbelt buzzer unfortunately.
My door plate says 7/25
2025 2026 4runner 6th gen Carista App v10.1.1 gets new features pwrwin
josiahg52
Josiah
Maine, United States
Did you find a Warnings menu? That's where i think I found mine. It wasn't in Seats, I know for sure.
ThatSickRIp
TSR
VA
2026 4Runner SR5
I think Im going to do the same with the ANC. Like you, not sure if its my imagination, but Im going to try again on a test drive with turning it on and off.
josiahg52
Josiah
I left it it on, ESE off. I guess I could try it off, too. All I know, with ESE off, it's more relaxing to drive. It feels calmer. It is definitely quieter and more comfortable feeling.
If you have the engine running and toggle ANC while not moving you can for sure, IMO, hear the difference.
redline61
Idaho
26 4Runner
I realized I didn't reply to you but I did search seats and warnings. I searched every single option hoping it was hiding somewhere.
Warnings had these options only:
  • Lane change flashing times adjust
  • Flasher sound volume
  • Window open warning
  • Slide roof open warning
  • Proposal service function
  • Rear seat reminder
Those are the only settings I have access to in warnings.
if you went into warnings and dings and these are the only options, then yours was made after june-2026, you can verify on the door plate driver side, it will have the month/year made in the bottom right of the plate, iirc
redline61
Idaho
26 4Runner
Yep, you're correct.
josiahg52
Josiah
will they eventually add the option. To turn off seat belt alarms in an update?
Probably. I mean, they would certainly want to. Did Toyota make it inaccessible, though?
