JOYTUTUS (Amazon) Rear Window Molle Panels installed
Maximus4R
Adam
Nashville
Installed these Amazon rear window molle panels today. Not bad for the price. Mine arrived damaged on the ends but this is because the amazon driver was man handling them at drop off. We watched them drop the whole box on camera. Install was easy. They do mount to the rear cross bar holes so it forces the rear up so that it’s really only pressure fitted in this position. I don’t have a good baseline for what good is as these are my first exterior molle panels.
Now I can finally store my wife’s and my important, daily gear.
2025 2026 4runner 6th gen JOYTUTUS (Amazon) Rear Window Molle Panels installed IMG_1173
2025 2026 4runner 6th gen JOYTUTUS (Amazon) Rear Window Molle Panels installed IMG_1177
2025 2026 4runner 6th gen JOYTUTUS (Amazon) Rear Window Molle Panels installed IMG_1175
2025 2026 4runner 6th gen JOYTUTUS (Amazon) Rear Window Molle Panels installed IMG_1174
2025 2026 4runner 6th gen JOYTUTUS (Amazon) Rear Window Molle Panels installed IMG_1176
kzrman
Maine
2025 Trailhunter
I've been looking for something like this. Are you using a ARB base rack?
Can you please give me a closeup of how these are attached. Thank you.
Maximus4R
Maximus4R
Adam
Nashville
No ARB rack for me sadly. These mount right to the standard roof rails. They use the rear cross bar holes, with three torx screws inserted from the outside/main panel.
2025 2026 4runner 6th gen JOYTUTUS (Amazon) Rear Window Molle Panels installed IMG_1187
2025 2026 4runner 6th gen JOYTUTUS (Amazon) Rear Window Molle Panels installed IMG_1186
Maximus4R
Maximus4R
Adam
Nashville
The bottom of each has two suction cups that hold the panels to the windows.
2025 2026 4runner 6th gen JOYTUTUS (Amazon) Rear Window Molle Panels installed IMG_1188
kburrito
2025 TRD Off Road Hybrid
Hows the visibility through the window while in the car? I assume it makes it into a real blind spot?
Is there a downside to having the crossbars more forward? I dont use crossbars for anything so i dont know if there's a downside
Maximus4R
Maximus4R
Adam
Nashville
Can’t see anything out of the rear sides with them but I’m using a Wolfbox rearview so I don’t have a good baseline for the visibility loss. I’ll admit that the cross bar being more forward looks a little off to me, but that might be because I’m looking for it specifically. The rear one no longer has holes to line up with this far forward. You could always drill one I guess, it’s still pretty tight though.
Maximus4R
Maximus4R
Adam
Nashville
How much did these molle panels cost you?
Right around $200. I figured at that price they were worth a shot. Probably selling the oem cross bars I guess, that should wash with the cost. At least until someone decides to sell an OEM ARB rack nearby.
Not bad! Hopefully you can get one in your area. I’ve seen a good amount of people remove the ARB rack.
kzrman
Maine
2025 Trailhunter
Thanks for the update.
rajib77
Raj
NJ
4RUNNER
I am planning to buy these. Do you still recommend these? Any issue with the suction cups or anything? Thanks.
