TRD ORP on 35" Yokohama Geolandar M/T G003 35x12.50R17, Method MR703 +35 Offset, Westcott Designs Preload Collar Lift Kit
dirtwheeler
That looks good. I'm hesitant to do the collar lift - wondering how it impacts drivability, sensors (e.g., dynamic cruise control, proximity sensors, cameras, etc.). Any issues so far?
papadop88
2025 4Runner TRD Pro
Don't worry about the nanny sensors with a lift. You'll be fine. As for drivability, as long as you don't go above what a WD lift gives you (2.5" in the front) you won't have any issues. With any lift though, never expect your ride to feel completely stock. It just will never happen. Ever. But that doesn't mean a lift or at least a preload collar can't improve the drivability. In many cases it does as the stock shocks and springs are very soft and create alot of body roll and nose dive under hard breaking.
FloRunner
Joshua
2025 4Runner ORP Hybrid
Is that the Prinsu Pro roof rack or the older one? Your build looks great!
T_Pomp
Anthony
Illinois
2025 TRD Off Road Premium
35's Yokohama Geolandar MT G003 35x12.50R17
Method MR703 17x8.5 +35 mm offset
Westcott Designs preload collar lift kit
Prinsu roof rack
TRD ORP on 35%22 Yokohama Geolandar M:T G003 35x12.50R17, Method MR703 +35 Offset, Westcott D...webp
I’m curious if you have taken your rig out fully loaded with this leveling kit installed? I just purchased it and not questioning my purpose due to the fact that I’m worried about the rear end sagging when loaded with gear. I think I probably should’ve purchased the front spacer and installed the heavier duty coil in the back.
2019 4Runner
Dale
4Runner TRD
Hello,
I'm wondering if you have any steering wheel shake with those tires? At highway speed?
Runner looks great. Thank you
Bigtex88
juxfin
texas
2019 trd pro
how is the ride with the geos? I had them on my 5th gen and loved the at first but didnt last me very long.
