Tie down accessories for the ARB 3/4 roof rack
Everybodyduck
Michael
2025 4Runner I-Force Max
The ARB website shows tie down straps (set of two) with squared off end pieces. There is also the outside springloaded eyelet attachment (sold in two), and then there are the interior eylets (sold in four pack). Any ideas of what a optimum amount of hardware is to secure assorted items for various occasions? Any pictures of these items at work or rest on any of your racks in the wild?
Everybodyduck
Everybodyduck
Michael
Okay, since I posted this, I learned from a fellow member that the new 3/4 ARB rack is compatible with ARB's base rack dovetail system and the T-slot system used by Thule and many other brands. I called ARB, and they confirmed that this roof rack is made exclusively for Toyota and will accommodate their base rack dovetail accessories and the T-slot systems of their competitors. How cool is that?
Everybodyduck
Everybodyduck
Michael
Well done. Thanks for the picture and the link.
bastarosus
4runner Trailhunter
rule5
Rob
I use these mounting base plates:
https://www.amazon.com/dp/B0CTB9SSBX?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
I had the same issue with the mounting pins being a bit too far apart and I therefore had to 'float' the base plate a bit higher than the rails so I could get the ideal position. If I didn't 'float' the base plate, the mounting pins bolts just 'collided' with the rails so a flat mount option wasn't going to work.
This worked out great and has held up very well over hundreds of rough miles off road.
It's also worth noting I had to purchase the missing cross bar (there is another thread about this) for it all to work.
2025 2026 4runner 6th gen Tie down accessories for the ARB 3/4 roof rack IMG_6589
2025 2026 4runner 6th gen Tie down accessories for the ARB 3/4 roof rack IMG_6591
DangItsDen
Hayden
rule5
Rob
No noticeable noise. The mpg takes a decent hit though especially if driving across the windy plains.
hussch85
Hussein
Cypress, CA
2025 4runner Limited Hybrid
Weren’t the m6x35mm too long for the roam mounting bracket? They would rub against the bottom of the box, i went w 1”nuts n bolts from HD
rule5
Rob
I had forgotten about that. Yes, they were too long so I cut them shorter with a Dremel.
hussch85
Hussein
Cypress, CA
I was hoping to find something more solid but that works
Has anyone used the rigid T mounts on arb roof rack? Might get for a second box
Gagi
Gavi
Valley Glen, CA
2026 Toyota 4Runner Trailhunter
Thanks for sharing, anything helps us new owners.
I’m planning to add a gas and water canister, possibly RotopaX, to my ARB 3/4 rack. Still researching what brackets and mounts I’ll need. If anyone has done this setup on the 6th gen Trailhunter Hybrid, I’d really appreciate your input.
Thanks again.
