Gas Gauge and Low Gas indicator Accurate?
Hello:
I am waiting my new 4R6G but believe I read about possible issues with the accuracy of the low fuel alert. Disclaimer, I initially liked at a lot of other vehicles so I could be confusing an issue from a different model. I looked at Grand Highlander, Sequoia, Ford Explorer, GMC Yukon.
From memory, the issue was the low fuel triggering after 13 gallons of usage when 6 gallons still exist in tank.
For anyone who has the 4R6G, when is your low gas gauge common on and at what approximate capacity left in tank?
Thanks.....
LLL1990
Toyota Camry and Ford F-150
If it's like all other Toyotas, it's going to be pessimistic and the light will come on when there's about 5 gallons left in the tank as you said. It's not an accuracy issue, Toyotas has it setup that way to keep people from running out of gas.
typically toyota sets the empty gauge (or mpg to empty on the display) at 10%-20% fuel capacity depending on avg mpg of a vehicle
i know on our 23 tundra is about 5-6 gals on a 32gal tank. its to ensure people dont burn up your fuel pump (from what i remember)
and your fuel gauge is lopsided in reporting, once you get below 1/2 tank you go thru it faster than the top half due to the way fuel tanks are molded.
personally in ND (especially in winter conditions) we dont usually go below 1/2 tank for safety reasons. its to ensure you have enough gas to weather out a storm if you get stuck in a ditch or back road until help comes too keep you warm
i know the wife starts freaking out once she gets to 1/2 tank even in the summertime. i give her crap for it outside of winter months.
Great info. I agree on keeping a tank topped up and not going too low.
It is a shame that the gauge and calculation could not be improved with software but I guess they are trying to protect those who would run really low.
Thank you.
the calc's are correct for a full tank, but from what i have seen toyota err's on the low side to ensure people dont run out of gas and builds in a large safety margin.
i mean on my 14 4R, ive run it down to E but i dont every remember going higher than 18 gals on a fill up if i did run it down that low
I wonder if the Carista software has any recalibration settings to adjust for the fuel gauge low fuel alert. Maybe change to 2 gallons or a lower percentage. My guess is not but worth asking.
youngolf
Southeast
Odyssey
I lived in hurricane FL……you always kept your tank topped for when you needed to vacate
gilhern
Katy Tx
2025 4Runner TRD ORP
I used Carista for the seat beeps but didn't see anything about the fuel light. It is indeed annoying. I have filled up right at 0 miles remaining and each time it is 15 gallons. So the light kicks on with 6 gallons left. That is way too high. When the non hybrid is only getting 250 gallons before needing to refill it gets super annoying super quick. I wish I could set it to 2 or 3 gallons left cause 6 is rediculous. Thats almost a 3rd of the whole tank.
k9Hiken
jesse
New Kent Va
2025 SR5
The gas tank is a 19 gallon tank. So with your calculations and total of fuel when filling up we make it a total of 4 gallons left not 6 gallons. Correct?
Serious question: Where the heck is the "fuel light" indicating you are low? Here is a photo of my dash before a recent fill-up. It clearly shows 28 miles to go with fuel gauge at about 1/10th of a tank.
2025 2026 4runner 6th gen Gas Gauge and Low Gas indicator Accurate? 20250627_075422
And here is some real data (last two rows) that can be extrapolated to show that at "empty'" (0 miles to go) you could expect there to be about 2 gallons left in the 19 gallon tank. (The "actual" distance to go is calculated as (19-fuel added) * Tank MPG.
Odometer ReadingMilesGallonsDist. to go -Before fill"Actual" dist to go?Dist. to go -After fillMPG TankGallons (total)MPG Total
7(fuel added)(mileage)
262255.015.719?53.2?16.215.7216.67
594332.015.699?69.8?21.131.4218.91
854260.014.1?90.4?18.445.5218.76
1216362.016.07328.065.9347.022.561.5919.74
1487271.011.767102.0146.6347.023.073.3620.27
But seriously, where is the "light"? (I am fully prepared to be embarrassed at my ignorance and say "D'oh")
page 581 of the owners manual
k9Hiken
jesse
New Kent Va
2025 SR5
Indicates that remaining fuel is approximately 2.8 gal. (10.8 L, 2.3 Imp. gal.) or less ď‚®Refuel the vehicle. this is on page583 of owners manual
Thanks. The warning lights and indicators section (page 82 in my manual) shows the fuel indicator in the same spot as in the photo I posted - lower right above the fuel gauge. But for me that indicator is always there - with an arrow showing that the fuel tank door is on the drivers side. Perhaps that indicator changes color when the distance to empty equates to 2.8 gallons and I just haven't gotten there? I.e., in the 2nd to last row on my table if I'd gone 3 more miles before filling up would the light would have changed to red or amber? (Note that I put just under 16.1 Gal in on that fill and 16.2 would be 2.8 left in 19 gallon tank). I know this is a bit silly and I can easily find out by getting the miles to go indicator under 25... So thanks in advance for "illuminating" me.
Also - I think my question, the data I provided, and k9hiken's quote of the manual (2.8 gallons left) addresses fairly completely the OP question. (And if the light really is coming on at 6 gallons left there IS a problem)
k9Hiken
jesse
New Kent Va
2025 SR5
have you attempted to topping it off until the gas is sitting in the spout? If Im not mistaking when i did that with my 5th gen it was about 2 more gallons that would take to fill it to the spout once the pump stops. I would then get about 80 miles out of the gas before it came off of full.
Thanks again for the reply k9, but I'm kind of confused by your responses. I'm not having any problem with light coming on (that was OP). I'm simply asking what it looks like when the light comes on since I've never seen it.
