cuhhhris
chris
2025 SR5 4Runner
Just installed some 35s this weekend paired with Westcott preload collar level kit.
Cutting Edge SR5
KO3 35's tires 315/70/17
0 offset Method 305 Bronze Wheels (17x8.5)
Westcott level kit: 2.5" inch lift front & 0.75" inch lift rear
Some rubbing even after level kit (required some slight fender liner trimming in the front + a little bit of angle grinding. Also uninstall the bump stops/mud guards (not 100% sure that's what they're called but it is pictured below,). Just three 17mm bolts. Super easy. Rears clear perfectly!
2025 2026 4runner 6th gen 35s (KO3) on SR5 + Westcott Preload Collar Level Kit + Method 305 Bronze Wheels 2025 4Runner 6th gen Ice Cap w: Bronze Wheels - 35s (KO3) on SR5 + Westcott Preload Collar L
2025 2026 4runner 6th gen 35s (KO3) on SR5 + Westcott Preload Collar Level Kit + Method 305 Bronze Wheels img_0044-jpe
Handoc
Greg
Pleasant Hill, CA
2025 4Runner ORP, Everest
Cutting Edge SR5
Nice!! Any rubbing?
FREEDOMEDIA
Nate
Oahu
2018 TRD PRO 4Runner, 2016 TRD PRO Tundra
Cutting Edge SR5
2025 4Runner 6th gen Ice Cap w: Bronze Wheels - 35s (KO3) on SR5 + Westcott Preload Collar Le...webp
2025 4Runner 6th gen Ice Cap w: Bronze Wheels - 35s (KO3) on SR5 + Westcott Preload Collar Le...jpeg
Looks awesome! Those KO3s ride so smooth, are lightweight and on the shorter side (34.4") so a bit easier to clear
cuhhhris
cuhhhris
chris
2025 SR5 4Runner
Nice!! Any rubbing?
Yes, even after the level kit. But it was just some slight fender liner trimming in the front + a little bit of angle grinding. Also uninstalled these bump stops/mud guards. (Don’t know what this part is actually called.)
2025 2026 4runner 6th gen 35s (KO3) on SR5 + Westcott Preload Collar Level Kit + Method 305 Bronze Wheels IMG_0044
cuhhhris
cuhhhris
chris
2025 SR5 4Runner
Agreed! Rocked KO2’s on my 5th gen TRDP, they were good still, but loving the KO3s much more!
cuhhhris
cuhhhris
chris
2025 SR5 4Runner
@cuhhhris how’s the ride quality / ride comfort on these tires compared to the stock setup?
Ride quality is not far from oem. Bigger all terrains you will always feel a little more bumpiness, but as far as the level kit it’s pretty damn close to oem. So overall I’d say it’s pretty comfortable compared to stock
griegert
Greg
Simi Valley, CA
2010 FJ Cruiser / 2025 TRD ORP
What did you have to angle grind? I have seen video on removing the part behind the front tires and on repositioning the wheel liner in front of the front tires, but saw nothing on grinding.
cuhhhris
cuhhhris
chris
2025 SR5 4Runner
I had to grind off a little bit of the bottom front bumper of where It would rub when going onto driveways so just grinded it down a bit. I couldn’t see any videos either but if I’m not mistaken most of the people that fit 35s that documented it had trd off roads which have the bilsteins for extra clearance.
jwhmtns5
Jeff
4runner TRD Sport Premium
Thanks for posting this! Definitely looking for inspiration as to other colors (besides black) that work well with this sweet silver color. I had bronze wheels on my 5th gen, so might go that route again. Love the stance too!
2025 2026 4runner 6th gen 35s (KO3) on SR5 + Westcott Preload Collar Level Kit + Method 305 Bronze Wheels IMG_0931
sevijose
Jose
Pennsylvania
2025 Toyota 4runner SR5
Quick question, are you not concerned with the inaccuracy of your speedometer? Or did you have it calibrated? You’re probably off by some at 60mph
