4running
TX
2020 4Runner SR5
Fastest privately owned 6th gen 4Runner build progress I've seen yet. Will this be a shows-only build or you'll be using it for camping / overlanding too?
ryno
ryno
sw. mo
25 4 runner
I'll be at all the overland expos , off road type events, and SEMA with it this year, then it will be used for trips camping etc
Trailhunter4R
Got my Icon alloys wheels in today, so I had to install one of the Toyo AT3's on a wheel and toss It on to see how it will look.
These are 17x8.5" +25 offset with 35x12.50.17 tires. No lift yet, so it's just for a quick pic.
Staying bare or going to fit mudguards / mudflaps to deal with the spray from the more aggressive wheels offset?
ryno
ryno
sw. mo
25 4 runner
well see what's out there, I've seen the extended flairs, and id like to run them , have not seen any flaps yet. the +25 does poke little and will make a mess, but not as bad as the 0 offset most are running.
ryno
ryno
sw. mo
25 4 runner
here is the poke
2025 2026 4runner 6th gen Heritage Blue 4Runner full build begins IMG_7165
Keroppi
Hawaii
Incoming 2025 4Runner TRD ORP
Any more mods? Had this bookmarked but haven't seen updates.
ryno
ryno
sw. mo
25 4 runner
been posting lots of detailed pics on separate post, guess I can update here all, kinda forgot about this thread since not much activity.
peak suspension
2025 2026 4runner 6th gen Heritage Blue 4Runner full build begins IMG_7304
2025 2026 4runner 6th gen Heritage Blue 4Runner full build begins IMG_7329
2025 2026 4runner 6th gen Heritage Blue 4Runner full build begins IMG_7328
2025 2026 4runner 6th gen Heritage Blue 4Runner full build begins IMG_7313
2025 2026 4runner 6th gen Heritage Blue 4Runner full build begins IMG_7301
ryno
ryno
sw. mo
25 4 runner
redline tuning gas strut hood props, get rid of stock cheap stock single rod
2025 2026 4runner 6th gen Heritage Blue 4Runner full build begins IMG_7374
2025 2026 4runner 6th gen Heritage Blue 4Runner full build begins IMG_7366
2025 2026 4runner 6th gen Heritage Blue 4Runner full build begins IMG_7369
ryno
ryno
sw. mo
25 4 runner
Installed many of these into a wide range of builds, yes you can add some factory switches, but these are way cleaner. You only need to run one small wire into the cabin area, all the rest of your acc wiring will be in the engine bay to the solid state relay block. With 80 amps continual , 2 30 amps, 2 20 amp, 2 10 amp , and 2 5 amp slots you can wire about anything directly to them. I custom made a mounting stand for it between the abs and fuse panel on the drivers side of the engine bay. Mounted the controller above the factory switch locations on the drivers side of the dash. The wiring I ran through the factory grommet with the stock wiring.
2025 2026 4runner 6th gen Heritage Blue 4Runner full build begins IMG_7627
2025 2026 4runner 6th gen Heritage Blue 4Runner full build begins IMG_7658
2025 2026 4runner 6th gen Heritage Blue 4Runner full build begins IMG_7657
2025 2026 4runner 6th gen Heritage Blue 4Runner full build begins IMG_7714
2025 2026 4runner 6th gen Heritage Blue 4Runner full build begins IMG_7713
ryno
ryno
sw. mo
25 4 runner
Installed some of etc SXTH element lower billet recovery hooks in black anodized and they look so much better the next stock!
These share the same fitment for the Tacoma. Its a simple 2 bolt swap, take out the stock units, bolts these in ,and have the confidence knowing if you need too, you have a solid recovery point now, and will look way cooler doing so!
https://sxthelement.com/collections/4runner-2025
2025 2026 4runner 6th gen Heritage Blue 4Runner full build begins IMG_7512
2025 2026 4runner 6th gen Heritage Blue 4Runner full build begins IMG_7510
2025 2026 4runner 6th gen Heritage Blue 4Runner full build begins IMG_7511
