Magnetic drain plug for oil change -- recommendations?
Wubzy
Josie
Charleston
what and how do I get a magnetic drain plug ?
mars001
2003 4Runner SR5 4.7 V8
I always replaced the stock oil drain plug with a Fumoto valve on all my cars/trucks/motorcycles at the 1st oil change to make all subsequent oil changes a lot easier.
Wubzy
Wubzy
Josie
Charleston
Are they universal?
mars001
No. They make different thread for different car/truck. That's the first thing I do after getting a new car. The one on my 2003 4Runner is still there after 22 years ?
Check out https://www.fumotousa.com/
I'm just a satisfied customer. It's also on all my motorcycles that subject to high vibration.
Wubzy
Wubzy
Josie
Charleston
I’m amazed at my own ignorance on these kinda thing.
I bought one, thank you for the lesson!
JCP
James
Bay Area
2026 4runner TRD Offroad Premium
I assume that the standard oil plug is not magnetic?
Any strong magnet stuck to the oil pan next to the drain plug will do. Just take it off when you do the oil change so the metal and flow out.
MStarmer
Michael
WA
2026 4Runner TRD ORP
If you're interested in a magnetic one you can get one from Amazon (GoldPlug). The nice thing is they're usually drilled for safety wire if you feel the need for a little extra protection. I've use many Fumoto valves thru the years and they are the most convienent with the ability to drain right back into the jug with a length of hose. I'm going to run the GoldPlug thru break in and the first couple oil changes then probably switch to a Fumoto valve later down the road most likely. https://a.co/d/06ZFVqSz
