Ticking Sound Coming From Dash Near Windshield
ryanc92
Ryan
6th Gen SR5 (2026)
I was able to get a video.
EastCoast
Great job capturing the sound, I have been chasing this for a while now and still haven’t found an answer. I agree with earlier comments that the noise is more prominent with hotter outside temps and bumpy roads, but I hear it all the time now unless I’m on the highway.
Our 4th gen is rattle free, so this is aggravating.
Tasc
2025 4Runner SR5 4x4, 2025 Tacoma TRD 4x4
ive noticed that the noise is only audible during the first few minutes of driving on local roads. when i get on the highway the noise goes away, even when getting back off the highway.
I see the same thing, usually mostly present right after taking car out for first time that day. The noise does seem to go away after driving for awhile. Didn't have the noise for first 3000 miles, now it comes and goes daily.
TRDBROG
NV
4R TRD PRO
What would it take to get a TSB going?
porkyfly
Mid atlantic
2025 4runner TRD Offroad
TSB's are issued by the manufacturer, we don't have control over that. I guess we can all complain to Toyota corporate? Might go to the dealer tomorrow but I doubt they can do anything. Rattles are like a death sentence because they are usually not diagnosable
porkyfly
Mid atlantic
filed complaint with NHTSA, everyone else please do the same so we can get sufficient complaint volume
2025 2026 4runner 6th gen Ticking Sound Coming From Dash Near Windshield IMG_5257
porkyfly
Mid atlantic
This was fixed by wedging a towel between the hood and the windshield cowl weather seal:
2025 2026 4runner 6th gen Ticking Sound Coming From Dash Near Windshield IMG_5271
Tasc
That does seem to make the most sense for the sound based on where it's coming from. I'll try the same trick to see if it fixes it, then need to find a better long term solution. But thank you for figuring this out if it does turn out to be the issue!
porkyfly
Mid atlantic
The towel is obviously not a permanent solution, it was just to diagnose the issue.
The issue is either caused by hood rattling against plastic cowl or cowl rattling against whatever's underneath it. All the towel does is put adequate pressure on the hood/weather stripping so the rattling stops. This makes sense as highway driving puts enough aerodynamic pressure on the hood to stop the rattling. As for why the rattling stops after the car warms up, im not really sure. Maybe the rubber weather stripping expands due to heat causing it to make better contact with the hood.
Let me know if the towel trick works for you
Tasc
I stuffed a towel on top of the cowl as shown, but unfortunately didn't stop the sound for me. I may try again and line the entire length of the cowl. But I think you are spot on about it being related to the cowl. Just need to figure out where it is rubbing in my truck. May even be where the cowl seals up against the windshield itself.
porkyfly
Mid atlantic
Can you take a pic of your towel placement, as well as a video of the sound you are experiencing? Here is a video of the sound the towel trick fixed:
DHermit
Orlando, FL
2025 4Runner Platinum
I have this issue on my 5th gen, and on my 6th gen the HUD rattles, BAD. Going to get some foam, remove it and reinstall
EastCoast
Towel on the cowl didn't work for me either after trying it in different spots in front of the driver. I had high hopes for this one, but no luck. It was quiet earlier in the day and then once the noise started it didn't stop for the rest of the day. The troubleshooting continues.
Tasc
attached video of the sound. Seems to sound more like a rattle on the mic, but in person it sounds more like rubber rubbing on metal/glass.
