See How Easy It Is to Install the Wireless 8 Switches Harness 2.0
MandRonline
Colby
Burbank CA
Toyota 4Runner TRD Pro
Hey everyone,
If you've been adding more accessories to your truck and are running out of switch options—or just don't want to deal with routing wires through the firewall every time—you might want to check out our Wireless 8 Switches Harness 2.0.
2025 2026 4runner 6th gen See How Easy It Is to Install the Wireless 8 Switches Harness 2.0 Wireless 8 Switches Harness 2 0
We designed it to make powering accessories a lot simpler. The wireless switch panel lets you control up to 8 different circuits, making it easy to run light bars, ditch lights, rock lights, air compressors, and more without ending up with a mess of wiring under the dash.
To give everyone a better idea of how it all comes together, we put together a complete install video that walks through the process from start to finish.
If you've already made a few electrical upgrades, you know how quickly wiring can get out of hand. This setup helps keep everything organized while giving you a clean, easy way to control all your accessories.
As always, if you have any questions about the system or whether it'll work for your setup, just let us know. Happy to help!
MandRonline
MandRonline
Colby
Burbank CA
Is this compatible on the Hybrid model ? What powers the switch panel /is it rechargeable ?
It’s compatible. The switch panel connects to the 12V bat and the remote is USB-C rechargeable.
pistol
OR
2026 Everest TRD ORP
Will this controller work with Diode Dynamics SSC1 fog lights to automatically turn on and off the backlight function when the ignition is on/off?
MandRonline
MandRonline
Colby
Burbank CA
Yes and we have trigger wires to turn on automatically with ignition if you run the wiring properly (trigger wires)
In general, you can control any 12v accessory. The M&R wireless controller has the capacity to run 8 independent circuits.
In a Hybrid, do you have to run the main wire all the way to the rear battery compartment or can it be wired somewhere under the hood?
pistol
OR
Thanks, any discount code available for forum members or veteran doscount?
MandRonline
MandRonline
Colby
Burbank CA
Yes sir! Use “4Runner6G” at checkout for 10% off.
MandRonline
MandRonline
Colby
Burbank CA
There are terminal points in the hood area for 12v supply.
Silver Bullet
D
Cali
2026 4Runner TRD ORP
Interesting setup. Is it able to handle a full setup? As in all 8 ports being used at once? Or Is it going to start popping fuses?
MandRonline
MandRonline
Colby
Burbank CA
Yes, absolutely. You can use all 8 channels at the same time. The system has a 100-amp master fuse, so the important thing is the total combined draw of everything you have connected.
As long as all of your accessories combined stay within that 100-amp limit, you can have all 8 channels in use without an issue.
