Low profile roof rack for SR5
mfoga
r4unner
I have very little room under the Prinsu Pro rack for the brackets of the RTT. I wouldn't want it any tighter
You used the wrap around mounts still? There are a few much better options for mounting a RTT to these type racks IMO. Especially on the Prinsu Pro since it does not have a flat surface on the bottom.
VG EDC
Vince
Calgary Alberta Canada
2025 TRD ORP Hybrid
I used what I had. I didn't want to add height to the setup either. I'd be grateful for other options, though.
mfoga
r4unner
I used the Sherpa rtt mounts which sit either 1/2 or 1" above the rack. Prinsu has a nice mount system if it works with the rails on the bottom of the RTT.
spyder40
Indiana
2021 4Runner ORP
I think Sherpa uses 7075 structural aluminum so stronger than the rest. For RTT just mount two of the bars to the tent and it will drop right into the rack so nothing sticks up. Also more solid since the RTT sits on all bars when mounted. They sell extra bars if you want all 9 bars in the rack when RTT isn't up there.
Furrypanda1121
2025 4Rrunner
I used these to mount my rtt to the westcott lo pro. Works well, attached to 3 bars using 6 mounts. When I want to remove the tent, I remove it with the 3 bars still mounted so I can just drop it on and go. Takes 20 minutes to mount and unmount it this way.
Rooftop Tent Brackets (Stainless Steel) | XTR Bed Rack RTT Mount
mfoga
r4unner
I tried those but had issues with their hardware being larger than what the rails would accept. I ended up with Sherpas 1” mounts. I could have gone with the 1/2” but 1” makes way easier to install and remove as I only remove one bar. The front has one set of mounts i can get to from moon roof. The middle has 2 sets on one bar that comes out. The rear has one set 1 bar in and I can get to it was a long ratcheting box end. Same is about 15-20 to install or remove. I love the mounting hardware on the other bars Full time.
ThatSickRIp
TSR
VA
2026 4Runner SR5
Down to the final 2 I believe; Wescott lo pro and Im still digging the looks of the Rhino Rack Reconn, but it appears to be 1" taller, so that would limit my tire size choice in the future, and to still be able to fit in the garage.
Ive got 4.75" from my factory rails to the entrance, so Im using 4" as my mod height allowance between roof rack and tires.
ROBERT18452
Robert
Scranton, Pennsyltuckey
25 Gen6 4runner limited
I would HIGHLY RECOMMEND Westcott Designs(y). The quality of their products is second to none. I guarantee you wont be disappointed. If you have any issues, you can call them during normal business hours. If you need support, you can call the owner of the company, and HE will assist you to the best of his ability. I have direct experience with this, and Jeff was instrumental in getting my issue resolved. WESTCOTT DESIGNS gets an A+ 💯% and has excellent products and customer service. If you need Jeff's cell phone number, I can readily provide it to you.
ThatSickRIp
TSR
VA
2026 4Runner SR5
Are you Jeff? :unsure:😂
ROBERT18452
Robert
No, I am just a stupid pollock from Northeastern Pennsyltuckey that is very satisfied with the product and the service I have been provided. Other members need to know which vendors they can count on
morsk
NY
2026 SR5
nic gorszego niz takie pierdolenie, myszl co mowisz chlopie
