Battery issues?
Hobb3s
2012 Jeep Grand Cherokee
Has anyone noticed the battery on their 6th gen fluctuating a-lot while driving? ive noticed my battery meter dropping quite a bit while driving and gradually getting charged.
i also have seen a few error codes around “lost communication” which based on my reading could be due to battery/power issues
2025 2026 4runner 6th gen Battery issues? IMG_5594
2025 2026 4runner 6th gen Battery issues? IMG_5593
which battery ?
hybrid battery will go up and down all the time
12v battery should remain stable 12v or higher
in regards to those error codes, what tool did you use ? Use
a proper scan device that is preloaded with 2025/2026 Toyota 4runner data so the
codes will be interpreted correctly.
if the 12v is low and causes any real issues there will be messages in
the dashboard alerting you there is a problem. if it is just your scan tool
reporting codes, [and it is not a techstream], and there are no real
issues you can determine outside that scan tool, ignore it.
Hobb3s
its the 12v, im on the gas only engine
and used the carista app
Carista does not interpret 6th gen 4runner audio system codes correctly, it is very limited in what it can do.
https://carista.com/en-us/apps/supported-cars/toyota/4runner/6th-gen
Test the voltage when engine is off then when running
BATTERY VOLTAGE (gas only)
Standard voltage:
11 to 14 V
If the voltage is below 11 V, replace or recharge the battery.
These are DTC's you need to worry about for 12v battery issues
For gasoline model:
The battery state sensor assembly detects the voltage, current and temperature of the battery. The battery state sensor assembly calculates State of Charge (SOC) based on the voltage and current of the battery and sends it to the ECM. Based on the signals received, the ECM adjusts the charging voltage of the generator assembly.
The battery state sensor assembly calculates the battery temperature based on changes in resistance of a built-in thermistor and sends it to the ECM. The ECM reduces the amount of charging current based on this signal in order to protect the battery.
DTC No.Detection ItemMILWarning IndicateDTC Output fromPriorityNoteLink
P058A1EBattery Monitor Module Circuit Resistance Out of RangeDoes not come onCharge warning light does not come onEngineBSAE Code: P058A2025 2026 4runner 6th gen Battery issues? IMG_5593
P058A46Battery Monitor Module Calibration / Parameter Memory FailureDoes not come onCharge warning light does not come onEngineBSAE Code: P058A2025 2026 4runner 6th gen Battery issues? IMG_5593
P058B49Battery Monitor Module Current Monitoring Performance Internal Electronic FailureComes onCharge warning light does not come onEngineBSAE Code: P058B2025 2026 4runner 6th gen Battery issues? IMG_5593
P058C01Battery Monitor Module Temperature Monitoring Performance General Electrical FailureDoes not come onCharge warning light does not come onEngineBSAE Code: P058C2025 2026 4runner 6th gen Battery issues? IMG_5593
P058D01Battery Monitor Module Voltage Monitoring Performance General Electrical FailureDoes not come onCharge warning light does not come onEngineBSAE Code: P058D2025 2026 4runner 6th gen Battery issues? IMG_5593
P062049Generator Control Circuit Internal Electronic FailureDoes not come onCharge warning is displayedEngineASAE Code: P06202025 2026 4runner 6th gen Battery issues? IMG_5593
P065C07Generator "A" Mechanical Performance Mechanical FailureDoes not come onCharge warning is displayedEngineASAE Code: P065C2025 2026 4runner 6th gen Battery issues? IMG_5593
P160200Deterioration of Battery Low CapacityDoes not come onCharge warning light does not come onEngineBSAE Code: P16022025 2026 4runner 6th gen Battery issues? IMG_5593
P161A87Lost Communication with Alternator Missing MessageDoes not come onCharge warning light does not come onEngineASAE Code: P161A2025 2026 4runner 6th gen Battery issues? IMG_5593
P162B87Lost Communication with Battery Monitor Module Missing MessageComes onCharge warning light does not come onEngineASAE Code: P162B2025 2026 4runner 6th gen Battery issues? IMG_5593
P16E818Battery Monitor Module Current Monitoring Circuit Current Below ThresholdComes onCharge warning light does not come onEngineBSAE Code: P16EA2025 2026 4runner 6th gen Battery issues? IMG_5593
P16E819Battery Monitor Module Current Monitoring Circuit Current Above ThresholdComes onCharge warning light does not come onEngineBSAE Code: P16EB2025 2026 4runner 6th gen Battery issues? IMG_5593
P16E81DBattery Monitor Module Current Monitoring Circuit Current Out of RangeComes onCharge warning light does not come onEngineBSAE Code: P16E92025 2026 4runner 6th gen Battery issues? IMG_5593
2025 2026 4runner 6th gen Battery issues? {filename}
Hobb3s
just did some monitoring , battery was jumping around 12.5 to 15.1 while running. i reseated the battery connectors and it was at a steady 13.8 after
1stRunner
George
Ohio
2026 4Runner TRD Offroad Premium
Nice job, also overlooked (especially in older vehicles) is a good ground, usually there are multiple grounds, so don't get fixated on checking voltage. Also you need to use the same grnd reference as the module you are testing, not the battery terminal.
Hobb3s
based on what im reading its part of toyotas smart charging system for batteries
just curious if anyone has seen this on their non hybrid vehicle
it also looks to be a feature for vehicles with ass which the limited does unfortunately
2025 2026 4runner 6th gen Battery issues? IMG_5598
1stRunner
George
Ohio
It doesnt matter, the point at which your vehicle is monitoring the battery voltage may not be the same reference point as the battery reference. I have seen this many times in the field, If you are measuring (or using you cars ecm ) to measuring the system voltage you need to use the exact same reference point at that connector, not the battery negative terminal.
here is how to test
7. INSPECT CHARGING CIRCUIT WITHOUT LOAD
CAUTION:
  • To prevent injury due to contact with an operating V-ribbed belt or cooling fan, keep your hands and clothing away from the V-ribbed belt and cooling fans when working in the engine compartment with the engine running or the ignition switch ON.
  • To prevent burns, do not touch the engine, exhaust manifold or other high temperature components while the engine is hot.
Pre-procedure1
(a) Connect a voltmeter and an ammeter to the charging circuit as follows.
HINT:
If a battery/generator assembly tester is available, connect the tester to the charging circuit in accordance with the manufacturer's instructions.
(1) Disconnect the wire from terminal B of the generator assembly and connect it to the negative (-) lead of the ammeter.
(2) Connect the ammeter positive (+) lead to terminal B of the generator assembly.
(3) Connect the voltmeter positive (+) lead to the positive (+) terminal of the battery.
(4) Ground the voltmeter negative (-) lead.
2025 2026 4runner 6th gen Battery issues? A125200C21
*1​
Generator Assembly
*2​
Battery
*a​
Terminal B
Procedure1
(b) Check the charging circuit.
(1) Maintain the engine speed at 2000 rpm and check the readings on the ammeter and voltmeter.
Standard Current
Specified Condition​
Result​
10 A or higher​
A​
Standard Voltage
Result​
12.7 to 15.3 V​
V​
If the result is not as specified, repair or replace the generator assembly.
Post-procedure1
(c) None.
8. INSPECT CHARGING CIRCUIT WITH LOAD
CAUTION:
Pre-procedure1
(a) With the engine running at 2000 rpm, turn the high beam headlights on and turn the heater blower switch to the "HI" position.
Procedure1
(b) Check the reading on the ammeter.
Standard Current
Result​
30 A or higher​
A​
HINT:
If the battery is fully charged, the reading will sometimes be less than the standard current. In this case, add more electrical load (operate the wipers, rear window defogger, etc.) and check the reading on the ammeter again.
1stRunner
George
Ohio
Again verifies the system function not the monitoring peripherals, thats why no one can troubleshoot anymore
